20 ft-lbs.
There is a thread for common torque values in the FAQ page.
https://forum.ih8mud.com/60-series-wagons/129878-suggestion-faq-common-torque-values.html
My dad taught me. Snug is good with drain plug with a gasket on the oil pan.There's two different oil pans and two different drain plugs which are different sizes. My advice is don't use a torque wrench on it, just common sense.
The threaded insert in these pans does not like to be over tightened. Ive seen more than one leak from deformation. Use a new gasket and i always use a thin smear of black RTV to seal and torque to about 20 ft lbs
I don't believe that either of this gaskets are for the oil drain plug. The steel one is for the diffs and the aluminum one is for the transfer case. I think the oil plug gasket is fiber. Toyota part 90430-12031.I've used both and both work fine. Whatever is available at local parts store. Stock I believe is a metal crush gasket.
@Spike Strip what does one do in this situation? I just replaced my drain plug/gasket and noticed the old one had like sewing thread wrapped around it and inside the pan hole. Torqued new one to spec and now it’s leaking.
@Spike Strip what does one do in this situation? I just replaced my drain plug/gasket and noticed the old one had like sewing thread wrapped around it and inside the pan hole.Torqued new one to spec and now it’s leaking.
What you saw as sewing thread was probably the remnants of Teflon pipe-sealing tape.
When I change the oil, I wait until there's nothing but a few drops coming out, then clean and dry the drain plug and put a bunch of Black RTV around the base/gasket of the bolt and a few threads up. Clean the female threads on the pan best you can and tighten the bolt to spec and let the RTV cure at least for a couple hours (best overnight), then fill with oil. Been doing that for 10 years now and no leak and the pic above is my oil pan.
You the man! Thanks a tonWhat you saw as sewing thread was probably the remnants of Teflon pipe-sealing tape.
