2f manifold gasket questions (1 Viewer)
wasatch
New to me fj60- I have found intake manifold has some serious leaks all around the gasket. bolts seem tight. After reading all the threads here and elsewhere on the subject it seems there isn't a lot of agreement on the best solution (double gasket vs single, gasket brand, sealant/no sealant etc. etc.). A couple of questions: I have read thet the remflex gaskets between the E/I are too thick and create alignment issues when trying to mate the manifold to the block, true? Or is the remflex kit good to go? Also, how many gaskets do I need to order to get this job done? From what I've read it seems I need six?? 1-manifold to block, 2-between I/E, 1-carb to manifold, 1-exhaust mani to ehaust pipe, 1- EGR gasket. Is this right? I just want to order everything at once and dig in.
Near Charlottesville, VA
As far as gaskets needed,
I used the felpro intake manifold. its 20 bucks and comes with both the gaskets for inbetween the manifolds. If yours arent leaking there, I would leave it alone because you are going to strip out the screws in the aluminium and going to have to helicoil the holes or re thread
I have gotten away with reusing the egr gasket with no leaks. I guess it depends on the age and condition. Mine wasnt that old.
The carb will not need a gasket it just bolts tight to the carb base which acts as a gasket.
I would get a new donut gasket for the down pipe too.
I hope this helps. I am no expert so I may get corrected, although I actually took an intake/exhaust manifold set off tonight.
wasatch
Thanks for the reply. Any way to tell if the gaskets between I/E are leaking or not? Carbon buildup? How has the fel pro held up? Did you use any copper sealant?
Steamboat Springs
That is not true.
though that may work, the carb base actually has a gasket on both sides of it.
check the parts diagrams in the service manuals and you'll see
They are cheap - like 2 bucks. might as well put them in there
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
