- Thread starter
- #21
1.- This raises another point & I can't be certain of what dist. you have. Is your dist a 'points' type ??
Good day John. This is the dist that I have installed a HEI INCAP, with advanced mechanical and vacuum, Chevrolet 250.
2.- Regarding 10v at the starter...all connections tight & clean ?? really tight and clean including all grounds. If you truly have only 10v at the starter, that is where I would suggest you spend some time.
Yes. All connections are clean and tight.
What do you mean with "spend some time"? I review it carefully?
3.- Can you get access to what we call 'Starter fluid' ? Comes in a can like carb cleaner. Spray it down the carb & if you have spark & the engine turns fast enough it WILL start. Might not run long, but it will start.
Here in Venezuela we do not have the liquid, at least I've never seen. Gasoline direct to the throat of the carburetor work?
Remember that petrol is ridiculously cheap here.
4.- I am just a poor shade tree mechanic trying to give you something to work on.
me too.. but thanks for your help!
Cristian.
Cristian.
