- Thread starter
- #21
The air gap is .008-.016".
Anywhere in that range is fine. The signal generator is a go/ no-go type of thing. It either generates a timing pulse or not. It cannot cause a weak spark, but it could cause an intemittent spark.
The resistance value for the ignitor is roughly the same for all 78-87.
The ignitor will not consistently fire one cylinder, but not another. It will either shut down for good, or misfire erratically. The ignitor doesn't know if it is hitting #1 or #4 or whatever. It just makes a spark after it hears the trigger from the dissy.
The dwell is built into the ignitor, and it is variable w/ RPM.
HTH.
FJ40Jim - With the dwell built into the igniter, that explains why my changing the air gap on the signal generator is not having any effect. FSM says the dwell should be much higher than the 30 degrees that I'm reading (at idle speed). Another reason to replace the igniter.
The signal generator is fairly new so I don't suspect a problem there.
What is difficult in determining the precise problem (besides the fact that I can't find my butt with both hands) is that it appears that 4, 5, and 6 are running fine. The miss is somehow associated with 1, 2, and 3 (since removing those plug wires does not effect in any way the miss). This leads me to think that I have a very specific problem rather than a random problem (erratic behavior). This makes me believe that the issue is not with the igniter... but, I've ordered the part and will replace it Monday or Tuesday of next week.
I'll know more then...
thanks.
