2f cylinders one and two are not helping...
Discussion in '40- & 55-Series Tech' started by Cruiser_GT, Mar 6, 2007.
  1. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    I want to make sure I've run all the traps before pulling the valve cover off...
    My engine has been missing after sitting for a period. I've replaced the contacts in the distrib (stock on the 78fj 40), plugs, and wires. Re-set the timing and still the engine misses.
    I revisited each plug to ensure I had solid connections when I noticed that disconnecting one and two plugs had no affect on how the engine ran. I even connected the tac and vacuum gage and saw no change. I'm getting spark through the wire.
    Checked the compression... not a problem.
  2. cruiser88
    cruiser88 SILVER Star
    11,879
    Media:
    3
    Albums:
    1
    286
    Feb 21, 2006
    Winston Oregon
    pull the cover off
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    Swap another spark plug lead to the dead holes....try another plug.
  4. grant5127
    grant5127
    5,025
    16
    Oct 31, 2003
    Meridian,TEXAS
    what are the #s
  5. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    Switched plugs out... no affect.
    Changed wires from known good cylinders... no affect.
    But, I found that 3 is not helping either. So 1-3 are not getting anything done. Just going through the motions.
  6. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    Just shy of 150 lbs. Right on spec. Right?
  7. grant5127
    grant5127
    5,025
    16
    Oct 31, 2003
    Meridian,TEXAS
    being the firing order is 153624... you say 132 is dead.. that's every other one... sure the cap and rotor are good? quality of spark is up to snuff? wires installed in the correct order??
  8. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    I'm with you. Adding the 3rd cylinder changes the whole picture (especially when the firing order is considered). The cap and rotor were replaced in my efforts to tune everything in the first place :) I am assuming that they are okay. I also replaced the coil... the only item that has not been replaced is the igniter (I'd rather not pay the big bucks to replace him... until I am sure that is the problem).
    Any ideas on measuring the quality of the spark? I held the wire to the block and it looked good. One bit me ... felt like it was pretty good quality :) I'm not sure how I could check it in a more quantitative way.
    Any ideas? I will double check the contacts on the rotor and the cap just to make sure.
    grand5127 - I suppose that I should note before someone else does that we have now determined that I'm "hitting on every other cylinder." LOL
    That explains a lot. :)
  9. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    Could this (missing on every other cylinder) be a symptom of a bad ignitor?
  10. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    22,546
    7,344
    Apr 14, 2004
    818-953-9230
    Based on your scenario, I would recommend temporarily swapping in a loaned dizzy AND coil [non-ignitor type] from an earlier cruiser to see what happens. It's a little work, but not nearly as much as pulling a cylinder head.
    Best
    Mark A.
  11. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    286
    Feb 21, 2006
    Winston Oregon
    igniters usually work or not work
  12. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    cruiser88 - Got it. I don't want to assume anything at this point. The Haynes manual has a digram that allows me to bypass the igniter with a .22 mfd condenser. Now all I need is a source of a .22 mfd condenser;).
    Mark - I hear you. The problem is finding a dizzy to swap. Thanks.
    gt
  13. grant5127
    grant5127
    5,025
    16
    Oct 31, 2003
    Meridian,TEXAS
    Hey,, Bama.. what is the condition of your dizzy?? does it have side to side movement of the shaft... are the lobes in good condition??
  14. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    Just pulled it out and took a peak. It looks good. No slop anywhere to be found.
    One other item I'd like to remove as a possibility in this whole mess. The FSM and Haynes manuals call for a dwell angle of 39-43 degrees. My reading is right at 30 degrees.
  15. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    286
    Feb 21, 2006
    Winston Oregon
    hmm.yep dwell is just as important as gap
  16. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    I didn't figure they were kidding around:)
    Do you know how the dwell is set? I assumed that the gap for the points should be used on the pickup (.018). I also test opening and closing a bit and had no major impact on my dwell reading. I suppose my meter (combo tach and dwell) is not getting it done.
    gt
  17. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    On the '78 dizzy, the points are replaced with a signal generator (pick-up). And, the .22 uf condensor bypass of the igniter will not work.
    As per thread searches... and SOR part nomenclature.
    Still no luck in determining how to set dwell angle for a dizzy equiped with the signal generator.
    BTW - Poser mentions on several threads that dwell settings to spec were not that important... at least not a low rpms... so I'm not putting a lot of hope in this correcting my problem.
    Any knowledge anyone has about the signal generator equiped dizzy would be greatly appreciated.
    :cheers:
    gt
    EDIT: I'm ordering an igniter (Napa $180 USD).
    https://forum.ih8mud.com/showthread.php?t=118614&highlight=signal+generator
    Other factors pusing me in this direction... Signal Generator has been replace, plugs replaced, plug wires replaced, coil replaced... only the igniter is original (partly because I agree that either it works or doesn't... but the above thread makes me believe that it can operate out of spec and cause troubleshooting problems). Either way, I'd rather replace it in my garage rather that on the trails.
    Lastly, I've had this LC a very long time and know a lot of details about it. I recall checking spark by holding the plug wire to the block and getting a very strong POP. That POP has now been reduced to more of a click. So my hypothesis is that the quality of the fire is now what id should be... we'll soon see.
  18. grant5127
    grant5127
    5,025
    16
    Oct 31, 2003
    Meridian,TEXAS
    I thought you stated "contact points"??? on signal generated options the air gap is adjusted...distance between signal rotor and pickup coil projection..... 0.008" if any of the components are rusty? that has a effect on the performance.. the pickup coil can be tested with a OHM meter for resistance......
  19. Cruiser_GT
    Cruiser_GT
    332
    Feb 5, 2006
    Huntsville, Al
    grant5127 - I'm challenged in many ways here... first, I don't know crap and second (partly attributed to the first challenge point) I'm not a great communicator.
    Thanks for the projection (is this the correct term? rather than gap?) value. I have been searching for that number for days.
    Do you know the specs on the resistance value of the igniter? Or a thread where I might find some details. I found .5-.7 ohm as spec for the fj60, but nothing for the 40.
    thanks much for the help.
    gt
  20. FJ40Jim
    FJ40Jim The Cruiser Whisperer SILVER Star
    10,136
    Media:
    1
    2,352
    Sep 26, 2003
    Lancaster, Ohio, USA
    The air gap is .008-.016".
    Anywhere in that range is fine. The signal generator is a go/ no-go type of thing. It either generates a timing pulse or not. It cannot cause a weak spark, but it could cause an intemittent spark.
    The resistance value for the ignitor is roughly the same for all 78-87.
    The ignitor will not consistently fire one cylinder, but not another. It will either shut down for good, or misfire erratically. The ignitor doesn't know if it is hitting #1 or #4 or whatever. It just makes a spark after it hears the trigger from the dissy.
    The dwell is built into the ignitor, and it is variable w/ RPM.
    HTH.
