acy76
Hello all--I am rebuilding the carb for my 1979 FJ-40. The secondary throttle shaft and power piston were completely seized and some of the choke and throttle linkages were bent. Someone was obviously in here before and did a number on some of the fasteners but I have managed to get it all back together and working smoothly.
Regarding the secondary, I can move the diaphragm through its full range of motion and the piece it attaches to on the shaft rotates without issue but it never engages with the shaft at all to move the secondary (doubtless this is the reason the secondary became frozen--inactivity).
I can't find any pictures showing how this is supposed to work. (The first picture in this thread shows it but not from the angle I need: 2f Aisin carb secondary question. (pics) - https://forum.ih8mud.com/threads/2f-aisin-carb-secondary-question-pics.515166/)
The throttle stop can only be installed one way that makes any sense, and the little tab on the secondary "puller" hits the stop when at rest (which sticks out at about 90 degrees, the rest of this piece is co-planar) but that is the only part in contact so the shaft never rotates.
Is the other tang on the throttle stop piece supposed to bend inward or something so it can make contact when the diaphragm pulls the actuator part? Everything I have seen seems to indicate this tab is meant to be on the "bottom" of the throttle stop, and if I try and assemble it on the top so it can pull on this stop, it doesn't make sense and seems to bind up.
Any advice? How is this thing supposed to go together so the vacuum diaphragm can do its job?
Thanks.
Thanks.
