24v starter relay cross reference? (1 Viewer)
Tucson
Is there such a thing?
I need a 28300-56020 starter relay for my 1990 HZJ73 are there any other part numbers that fit the bill?
thanks!
Used on the 60, 70 and 80 series.
Might also be found on a Dyna.
You can open up the relay to see what's going on.
Make certain you're fusible link is good. Try running a wire from your battery to the relay if in doubt as a test. I have a secondary fused line with a momentary switch which allows me to start or bump engine using 12 volts.
The relays seem fairly stout.
After sitting a couple days it turned over, started, but the starter kept running. Turned off the truck and the starter stopped after another couple seconds. I'm reading thats the sign of a faulty SR? The same issue happened maybe twice over the last 6 months where the starter would keep running for a couple seconds but I didn't realize thats what it was. Oof
