24V AC Amplifier (1 Viewer)
Engineer8000
CAPE FEAR ELECTRONICS
SOUTHPORT NC
Website
forum.ih8mud.com
Does anyone have a 24V AC amplifier they would be willing to send a picture of top and bottom of the circuit board? Thanks in advance.
It would be in the evaporator assembly, you will see a wire harness leading to it.
Some pics from @jblueridge. Looks like this is a slightly different version @Engineer8000 it's got a 7 position primary connector with a single 1/4" spade off to the side. The harness I have is a single 9 position connector.
Thank you for posting. Can you tell me the number on that 9 pin IC and the transistor? Thanks.
From @jblueridge:
The ic is. Toshiba t2333 8703k Japan
The printing is on the side facing the lone 1/4” quick disconnect terminal.
Transistor is more cryptic.
D667
C
6E2
The large main connector has 7 flat spade-like pins.
4 in the bottom row, 3 above.
When sun shines again I’ll get a macro photo.
Yes, from my BJ74.
Denso # 077300-0860
Main connector pics
Both the IC and transistor are common denso components. I will work on making a schematic based on these photos. I have the parts to reproduce this. Thank you very much for posting.
Can you tell me how many wires are actually connected in your case? Toyota had a habit of using connectors with more terminals than required. Do you have the schematic of the AC amp external connections for your truck? Can you post a picture of your 9 way connector, thanks.
@Engineer8000 I'll take a look when I get home this weekend. I have the FSM as well so we can figure out the full harness most likely.
Also @jblueridge says he's having troubles with his, his AC amp is currently overridden. I guess we'll want to figure out the pinout for him as well and scope his harness to see what's acting up.
I have an FSM copy and it gives instructions on how to test.
But that makes me like a monkey with a multimeter.
What I’d like to know is how this circuitry is supposed to work.
There is some evidence of wire/electrical tampering on my truck.
Can you post a copy of the applicable pages of the FSM related to the AC amp for your truck?
Can you post a copy of the applicable fsm pages for the ac amplifier that you have? Thanks.
sorry, can you also tell me the values of the other two ceramic caps, I see the one is 0.1uf (104) but need the other two. Thanks.
So the black cylinder and these disks are 2 kinds of capacitors?
Pages from manual. maybe too many.
  • aircon electric.pdf
Thanks for the information. The black cylinder cap is an aluminum electrolytic, the small discs are ceramic. There are many other types too. I have not checked the connector terminations yet, but the good news is this is simply an FJ62 AC amplifier with a few different resistors. The circuits are the same with a few resistors changed to deal with the 24v. And a 24V relay.
Edit, the connectors are wired different. This can be fixed with a short adapter harness. I am curious to see how the @repentsinner connector is wired.
