2020 tundra wheels on 2000 lx
Detroit
Pretty sure these will fit, but just want a sanity check before going any further with picking these up. Wrapped in defender 275.65.18.
They will fit right without issue?
Confirmed fit.
If you don’t have wheel spacer in the front you won’t be able to put the center cap back on unless you drill a hole in the cap to clear the hub dust cap from hitting it.
They fit. But he’s right, front center cap won’t fit without spacers or hammering dust cap flat.
Is it safe/smart to hammer the dust cap flat? I got a set of 20" wheels off a Tundra Sport to put on my 99 Land Cruiser and I'm debating spacers vs. hammer.
Confirmed fit.
What width wheel spacer did you use?
@PJM I am using 1.25” hub centric Bora wheel spacer for almost 3 years now and so far no problems with it like vibration or wobble in high speeds. I used blue loctite for the spacer opened-type lug nuts and tightened it to 98Lb/ft.
Thanks! I just ordered my Bora spacers.
My mechanic buddy used a press to flatten the dust caps for me. No spacer or removing material from the inside of the wheel cover was required. The 20" wheels off a Tundra are a big improvement.
Wow that totally modernizes it
