2018 LC w/ Warped Rotors: Advice on replacement
The Akenbono pads solved the shuddering for me - not a big fan of Toyota pads at this point. Similar issue with my Lexus is what brought me to that brand. Just happened to fix the shuddering issue on the LC as well.
Which Akebono are you using? I see several options.
I will never run akebonos based on my experience using their euro ceramics slowing even gradually from 130+ on a past vehicle.
Shudder right after a dealer rotation could very well be warped rotors, possibly from not torquing the lugs evenly.
Did you ever try the 319 stoptechs? Truck model?
All I’ve used were the OE Toyota pads and TRDs. The latter need care to avoid uneven deposits and bedding as soon as that starts but otherwise work great. I drive my rig pretty hard so others may not have this issue.
My point was if akebono released a pad that performs that poorly I don’t trust their product development in general.
Passenger side pics below. Looks significantly more evenly worn than the left.
I never grabbed a photo of it sadly.
Not sure what to make of all the scoring on the rotor though.
Felt smooth to the touch through gloves but obviously its not evenly deposited on.
Seems like they are applying out of parallel to the face.
There's definitely no lube on those pins. Do you feel or hear significant drag when you turn it by hand? As for the scoring, that's from either hard points in the pad or debris that got in between. Visually, it doesn't look bad from the pic.
