- Thread starter
- #21
I bought a ScanGauge - figure I'd use it again someday...A code reader is $20 or less at your local auto parts store. Almost all the stores will also loan you a more advanced $200 version if you ask at the counter.
None of those plugs look like the FSM plug pictured, which isn't too surprising, There are many regions and models and nav/non nav too. I'll look for one of the two white plugs pictured. I suspect it is the smaller, 10 pin, just need to figure out which pin.
You'll need a voltmeter to test voltage. These are also around $20 at your local walmart, target, hardware, or auto parts store.
I have a voltmeter that I'm semi-familiar with using.
Thanks so much for your help.
