@ Steve - what suspension kit are you running?
Hi,Just thought some of you might be interested in what my signature ride looks like:
http://i219.photobucket.com/albums/cc18/gaijinnv/ToyotaLC200_1_19JAN13_zps85df5db6.jpg
Using 1 differently sized tire is not likely to damage the diffs for short term emergency use. I would think however that it could cause other issues in panic stop or loss of control situations, that is why they are recommended for only temporary use.
As for the science behind choosing the correct tire pressure, I've took a more "test it and see"approach. With the car loaded for my normal load, I wet the tires and drive over some dust on a flat surface. This causes the dust to stick to the parts of the tire actually contacting the road, then you can see what the contact patch looks like.
On my new set of tires I noticed that the patch with dust on it only ended up being the middle 5 or so inches of tread at the recommended pressure. So I lowered the Psi a bit and this caused almost the entire width of the tread to make contact with the dust.
So the case of my 285's I ended up having a contact patch of 9 to 10 inches wide instead of 5 to 6 inches wide at the recommended pressure. This is on MT's.
Maybe that is not a good way to do it, but it seems like I should use more of the 11.2 inch width than I get at the recommended pressure.
Am I flirting with disaster?
I should have mentioned I am talking about my 76 series. My 285s are 285/75/16. I don't remember the specific values (truck is at home, I am at work). But I think Toyota recommended 38psi with low load and I found that 34psi gave me much better road contact.
I realize that the pressure will be very different between the 200 and the 76, that is why I didn't mention pressure values in my original post. But the same concepts apply.
My current tires are called "GT Radial Adventuro MT". They are LT285/75/R16 and indicate that they have a load rating of D. They were meant to be cheap temporary tires until I get my lift and go with 35 inch tires, but the lift has been delayed and I have been happy with the tire performance so far.
The stock tires that came from Toyota were Dunlop (Grand trek I think was the name), they were 265/70R16C.
Attached are the stickers by my driver door. They are different than on your 200.
Apologies if this is a rookie question, but does anyone know the total height with the TRD 17"wheels and BFG 285 70 R17s (including roof rails/ sat antenna)?
Originally, I was planning on a 2"OME lift with the 285 65 R18 BFGs on stock wheels, but my office garage has a low ceiling (6'8" or less) and it wont fit the extra 4-5 inches in height from this set up.
Hoping the TRD/ BFG set-up that Gaijin is rocking will be a workable option.
Looks awesome.
Add 2" to that 77", however, and you are flirting with disaster if you are up against a "hard" 80" (6'8") of clearance.
HTH
gaijin, i didn't quite get the above 80'' comment..can you please elaborate? thnx.
Your office garage is 6'8" or 80".
77" + 2" lift = 79" or 6'7". Considering that all of these measurements are somewhat approximate, the calculated height of your Cruiser with a 2" lift is dangerously close to the height of your office garage.
OK?
