- Thread starter
- #141
Yes, as you say, that could definitely happen and I suppose might be my issue.FWIW - I have a 95 Porsche and my DME relay went out on me the other day with very similar symptoms. I was on the highway and the car lost power, shut off and the lights on the dash went on. I would pull over and the car would restart and then die after a few seconds.... Apparently, once the contacts (solder joints) in the relay cracked internally, the heat (and expansion) would cause the contacts to stop...um....contacting. When the car shut down, it would cool just enough to contract and reestablish contact until it heated up again and lost it.
My point is that the relay's you checked (like my DME relay) would checkout as operational when cool, but not when up to temperature..... Could you subject the relay(s) to heat while testing them?
My dad knows a lot about electronics and he said it could even be the tracing on a circuit board that heats up just enough to break contact when energized and then cools just enough to make contact again. I sure hope that's not what I'm dealing with... Although it is a possibility.
My logic (although very flawed) is that this seems to have a time component. Along this path are several plausible scenarios:
- Actual time, like clock time on an ECM/ECU
- Some sort of mode switching that happens at a certain pivotal moment (say OL to OL drive) - when the ECM tries to read some sensor/sensors and the input results in a decision to shut down
- A byproduct of a mechanical issue (like for example, the fuel pump runs, but can't spin fast enough and that is how long it takes to consume the properly pressurized fuel in the fuel lines).
- A boundary condition in a sensor - if for example the voltage drops below a threshold value and the processor drops into a failure mode
If I get stuck much beyond the weekend, it is going to the dealer. I will have exhausted my ability and willingness, and will pass it on to the experts. I'm afraid of what that might cost if it comes to that, but at some point, I'll need to accept it.
What kind of Porsche? I'm a huge fan. I have two 911 (996) coupes right now (one that I'm trying to sell). I'm chasing CELs on one of those too (probably a vacuum leak).
As an aside, we had three automobile related failures in our household in the last week. This one, my wife's car had a cell in the battery die, and the 911 I mentioned above. I'm not feeling especially lucky. At least my wife's car was easily fixed with a new battery...
