2010 lx570 code po 304 UPDATE #2
Put a pull handle and socket on the crank bolt and turn it. It will move.
Could pull the fuel relay and that will avoid start on crank. Still random on where it stops.
Can someone explain how if I shut the engine off during a misfire then immediately start it back up the light stops flashing and misfire is gone. Does this point to anything? I know something is not right with that #4 misfire but how can this be?
I read it as a 'cold' vs 'not cold' kind of thing. Like if you had a fuel injector flooding a cylinder while truck is off. Then it tiggers code on start. An immediate restart wouldn't have that cylinder flooded as no time elapsed, so no code. There are of course lots of other potential causes . . .
Ok. I'll be digging deeper this weekend
Ok here's the result of my further diagnostics. I removed cylinder 4 plug and coil, started engine let it run for 10 seconds. Found lots of wetness on piston top (was dry before starting engine). Re installed plug and coil on cylinder 4. Removed coil and plug from cylinder 2. Very slight wetness on piston top hardly any. Started engine back up for 10 seconds with cylinder 2 plug and coil removed with coil and plug back in cylinder 4. Shut off, pulled plug from cylinder 4 and found plug soaked with gas and very wet on piston top just like my earlier pictures of that cylinder. Checked cylinder 6 and found very little wetness. So I think for some reason there is too much fuel being distributed into cylinder 4 at start up. It will come out of the misfire after about 20 seconds. I just drove 100 mile trip and no misfires when driving (other than at start up). Feeling good that this might not be a coolant in cylinder issue. If you've read this far without getting confused congratulations. I also took a former suggestion to use a long q tip into the cylinder and it smells like gas on the q tip. Tomorrow I'll be playing with the injector.
Good progress. Move that injector and see if the problem follows. I'll be hopeful it does.
Parts-cannonfire isn't free, so move it to confirm failure.
And what about the other injectors? I work at a toyota dealer and we have the pressurized can of fuel injector cleaner that hooks up to the fuel line. I'm thinking maybe install the new injector and perform the cleaning procedure ?
This was the spark plug from cylinder 4 after 10 seconds of run time. Soaked
At 235k you're due for your second set of coils and plugs unless you know they were done recently. Can avoid the spend, sure, but the truck will eventually pitch a fit and you'll have to put the money into it to fix the issue.
Yeah. I'll put the coils in along with new spark plugs. Do you think I'm OK only replacing 1 injector (assuming it needs that 1 injector)
Do you suggest I do that instead of just replacing the injector right off the bat? I'm leaning towards moving it first to give me peace of mind.
Just detach the #4injector harness and test resistance on the two terminals, per my earlier post.
Replace if it is out of spec.
In fairness, the injector can be in-spec electrically and failing/failed mechanically.
I read somewhere about someone having a broken valve spring. Would this only show itself an initial start ups like mine is doing. After it comes out of the misfire it runs perfectly smooth for many miles
No. Broken valve spring would run like crap and make a TERRIBLE noise.
