Hello all,
I've got a 2006 LC that will not crank. I've got 12.8 volts at the battery (1.5 years old) and clean terminals (that I nonetheless cleaned again to make sure they aren't the culprit).
The vehicle won't crank at all and I cannot get the OBD-2 scanner to work with it. It shuts off when I turn the car to "ON". With the key in the "ON" position, the only lights that light are the "RSCA OFF", the tire pressure light, ABS light, occasionally the CEL, and the "BRAKE" light. All these lights are very dim and flicker, and none of the other lights illuminate.
Any thoughts as to where I should start? I pulled the EFI fuse and swapped with a spare and nothing. I also confirmed the security light goes off with the key in the ignition. Would the OBD-2 issue be with the car or the scanner?
