2003 470, Maintenance Log & Build (4 Viewers)
1994LCNM
GOLD Star
New Mexico
Log of the build starting in Jan 2025.
Owner #1 and #4 had all the records, but owner #2 and #3 did not. I wonder if I can track down the records...
Additional items:
Wheels- 4x4 Engineering Bradley V’s (including spare)
Tires- Falcon Wildpeak AT3’s (including spare)
Suspension- Old Man Emu
Adjustable Height Control (AHC) delete
Dobinson’s rear springs, Upper Control Arms, and Lower Trailing Arms
Slee Sliderstep rock sliders
Prospeed Roof Rack
Retrofitted LED headlights (818 retrofit's P1 bi-LED projector. 50 watt 5500K LED projector. LED high beam bulbs)
Infrared tint
Lloyd’s mats
2003 Lexus LX 470Received Jan 2025
08/20/2025OEM Fuel Filter Assembly, Denso
229,642
07/09/202577740-60440 New Charcoal Canaster, OEM
228,265Exhaust Leak Patch
Driveshaft Zerk Replacement X 4 on rear shaft
Lubricated all 6 Zerk points with:
Valvoline Synpower Grease Tube (Moly)​
04/01/2025Polish fog light housing X2
224,987Install 1156 LED Amber Turning Signal Lights (Phinlion 3600) X2
Install H3 Yellow LED Fog Lights (Marsauto H3LL) X2
Install LED 2825 Turning Signal Lights (Sylvania) X2
03/01/2025Speaker Rebuild (Simply Speakers FSK-LX470 + MI-1291FG)
224,498Front Driver and Front Passenger Rebuilt Speakers
50% Extended Life Sealant applied to both Driver and Passenger Lower Speakers
50% Extended Life Sealant applied to both Driver and Passenger Mid Range Speakers
Rear Driver and Passenger Rebuilt Speakers
50% Extended Life Sealant applied to both Rear Driver and Passenger Speakers
Sub Rebuilt
50% Exgended Life Sealant applied to sub
02/15/2025RSCA, Rear Vent L/R, Mirror Illumination Replacement CEC Industries #8111 Bulbs
224.324Night Vision Switch Bulb
Charge AC System R134a
High Pressure Top A/C Line Rubber Mounts X 2
New A/C Compressor (Denso)
High and Low Pressure O-Rings to Compressor
A/C Compressor High Low Bolts and Gasket
A/C System Vaccum and Charge - 3X Bottles of 134a
01/27/2025Belt Tensioner and Pulley
223,675Idler Pulley
Power Steering Hose Return - Extended Hose for Bleed (Stock)
Power Steering Hose to Pump (Stock)
Power Steering Reservoir Replacement
Degrease Power Steering Pump and Flush
Serpentine Belt Replacement
New OEM Toyota Clamps for both Power Steering Lines
Power Steering Fluid Flush and Replacement (Valvoline Max Life Full Syn ATF)
Tighten Valve Cover Gaskets
Valve Cover Heater Hose (5/8') Stock Replacement
Skid Plate Foam Replacement
01/25/2025New Front Brake Pads (Power Stop Evolution) (Both Sides)
223,650Brake Fluid Flush (Valvoline DOT 3&4 Synthetic)
Trail Tailor Extended Rear Sway Bar Links and Upper Bushings
Super Pro Rear Sway Bar Link Lower Bushing Kit
Slee Stainless Steel Brake Lines (All 4)
01/16/2025Recall #1: Steering Shaft Replaced
223,404Recall #2: Curtain-Shield Airbag (CSA) Airbag Control Module
01/15/2025McMaster-Carr
223,321Fuse Box O-Ring
01/09/2025Oil Change
223,044Full Synthetic
5W-30
Multipoint Insp. Check. Ok
Tailgate Hatch Shocks X 2
5/21/2024Warranty
211,623Left Drive Shaft Boot
8/6/2024Oil Change
217,780Full Synthetic
5W-30
Tire Rotation
Front Axle Cap
4/9/2024Service
211,623Oil Change
Full Synthetic
5W-30
All function test
Clean brake pads
Both front axels
Wheel Bearings
Tow hitch bolt rethread
VGRS Motor
Dobinsons Up-Contr-Ar
Wheel Alignment
Tire Deflator (Gift)
Front Grill Touch Up
11/30/2023Service
205,453All function test
Service
Oil Change
Full Synthetic
5W-30
Tire Rotation
Cabin filter
Engine air filter
Brake fluid exchange
Fluid
7/11/2023Service
198,996All function test
Service
Oil Change
Full Synthetic
5W-30
Tighten battery terminal
Troubleshoot dead bat
Outer mirror replace
Steering wheel with
customer part
Paint wheel hubs
6/16/2023Service
198,552Replace rack and pinion
both tie rod outer ends
Remanuf. rack and pini
Outer tie rod
Outer tie rod
Power Fluid
Brake Parts
Waste
Front sway bar bushing
Polyute
Bushing
4 wheel alignment
Pass. front axle boot
Boot
Rear lower
Rear upper
Rear springs upgrade
Hours
New front shims
Front rotors
Front pads
Shims, brake
2/20/2023Service
195,096Replace heater and
water hose
Rain sensor
Glue
1/17/2023Service
194,006Oil Change
Full Synthetic
5W-30
Inspection
Re-calibrate steering
8/9/2022Service
189,864Inspection
Oil Change
Full Synthetic
5W-30
6/8/2022Service
188,669Timing belt hours
Timing belt kit
Drive belt
Thermostat
Thermostat Gasket
Seal, cam
Seal, crank
Waste
Reseal cam seal housing
Radiator assembly
Radiator cap
Radiator hose upper
Radiator hose lower
Coolant
Alternator assy
Valve cover gaskets lab
Gasket set
Set
Coolant water hose fitting
Cabin air filter
5/24/2022Service
188,382Pre owned inspection
Rear rotors
rear pads
sliding pin service
shim and contact point
03/30/2009 to 05/24/2022 (Owner 2 and 3) are missing records
3/30/2009Service
55,996Lexus Link Sys Removal
3/9/2009Warranty
55,023Transfer case leaking
Resealed
10/23/2008Windshield Wiperd
50,787
11/7/2007Replaced Battery
43,588
4/18/2007Replaced Air Filter
42,4564 Wheel Alignment
Spin Balance
Front brake pads
Deglaze rotors
Lube Slides
Replace Serpt. Belt
Replace pass dr mirror
12/17/200640k Mile service
37,055
11/26/2006Replace right front
36,112low beam bulb
8/8/2006Replace both mirrors
34,240Replace rear DVD plyer
Replace headrest plyr
Replace DVD head rst
8/2/200635k mile inspection
34,045Rear brake pads
Deglaze rear rotors
Lube slides
Lube left door catch
Roof rack tighten
3/21/2006Replace air filters
28,44930k mile service
11/15/2005Navigation screen
23,174replaced
DRL Resistor
11/1/2005Replace backup batt
22,392
10/20/200525k mile service
22,390
1/31/2005Update Nav
17,939
6/13/200415k miles service
13,885A/c Filter
Ash tray
Cup holder
Replace right door step
3/15/200410k service
10,447Roof rack bolts
tighten
12/11/20035k service
6012center caps tighten
9/8/20031k miles service
1672
7/23/2003Mount and balance
15wheels
Gold emblem
7/27/2003Delivery inspection
5Autoguard
Etch registration
Shame it doesn't still have the ahc. It rides so much better than the spring and shock setup. I would only recommend removing if the lines were rusted out. Nice looking rig though.
List of to-do's for 2025:
1. Front Driver Bottom Seat/Cushions
2. Front Driver Back Seat
3. Front Driver Arm Rest
4. Center Console
5. Front Passenger Bottom Seat/Cushions
6. Front Passenger Back Seat
7. Front Passenger Arm Rest
(Sand Stone Ridies- Full grain nappa, middle & 3rd row)
8. Complete Rear Seats
9. Full Carpet Replacement
10. Interior Touch-up Where Needed
11. Cat Back Exhaust System Replace
12. Evaporator Seal
13. Fuse Box Gasket
14. Heater Blower Fuse (Check all fuses)
15. Engineering Bradly Center Caps
16. Cabin/Engine Air Filter
17. Spark Plugs and Coils/Wires
18. Speaker Rebuild (Simply Speakers FSK-LX470 + MI-1291FG)
19. Trail Tailor - Hidden Winch Mount, 100 Series
20. #8111 Builds / Cluster Bulbs
21. Interior Bolts Tighten
22. Interior Sound Mats (Kilmat 50 mil 50sqft)
23. SS Slee Brake Lines
24. Idler Pulley
26. Power Steering Reservoir
27. Power Steering Hoses
28. Power Steering Clips
29. Tensioner and Pulley
30. Skid Plate Foam
31. Rear Sway Bar Link Bushing Kit (Super Pro)
32. L/R Rear Sway Bar Links W/ Upper Bushings (Trail Tailor)
33. A/C Compressor and O Rings
34. A/C Line Rubber Mounts X 2
35. Window Belt Moldings
36. Clean door motor
37. Charge A/C X3 Cans
So I took off the fuse box cover. It was missing the gasket/O-ring completely. Good thing I checked. I put in the McMaster-Carr gasket/O-Ring in today. It felt spot on, not too snug but not loose.
Here is the one that I had ordered from another members recommendation on here. When you go to set the gasket, DON'T stretch it. If you stretch it, it won't seal correctly. Just push it in without pulling it. Use a quarter to set it in directly down.
Also, click on the 10 under Length, ft. This will select 10ft. I choose 10 in case I messed up and I did. So give yourself enough length to try it out. I still have enough for 1 more replacement as well.
Awesome, thanks!
Pulled the tensioner and idler. Looks like both were on their last leg. Huge power steering leak as well.
Got the pump cleaned but I got some water and degrease in it. I'll put some power steering fluid through it before I put it back in to flush it out.
