200 Vs. 250 FE - Owners Perspective (1 Viewer)
You’d have to wheel it with too much skinny pedal to break a front differential- I’ve never had any issues knock on wood..
Some reports are breaking on places like icy driveways. A front locker usually fixes the issue, but you've still got relatively weak CVs to deal with. Locker plus HD CVs seems to be pretty bulletproof.
Unfortunately the 100 is a big pita to change on the trail. The 5G 4R uses a bolt together assembly to attach the lower ball joint, so trail swaps are a breeze comparatively. But they're also pretty strong so breakage is rare. I started carrying two trail spares plus a rear drive shaft as my base kit. After 8 years I dropped to carrying only one and never broke one.
The 100 does have much better factory gas tank skid and rear axle - I've only seen one 8.2 break and that was aftermarket ring gear failure. But it's obviously smaller and weaker. Gas tank skid really is a weak point on the 4R. It's low and gets hammered on harder trails.
On my 3rd Gen 4Runner the axles would snap if you looked at them wrong.
The CVs are pretty big on a 100- I imagine larger than a 4Runner/taco. I’ve pushed mine hard and drive home a thousand miles after the seals were blown.
Not sure. I've seen more frequent trail breakage on the 100s. Infinitely more because I've seen a handfull of 100's and never seen a J150. But that's just anecdotal. 100's are a lot older too. For rough comparison - this is a minitruck/FJ40/FJ60 birfield on the right vs a J150 on the left. The bell is probably similar an FJ80. If I had an 80 laying around I would have grabbed a pic, but I unfortunately I didn't.
I have read exactly 0 reports of CV failures on the 120/150 platform forum. That is of course anecdotal, but it appears to not really be a problem.
Conversely, several folks have blown up 8" diffs. I have not seen a report of a failed 8.2.
Just want to share pics of the front CV axle off the UZN215 (left) next to J100(center and right).
