200 series 17" wheels fit my 100 series (1 Viewer)
Not a bad looking set of wheels. Have you asked the guys on the 200 forum?
Looks like the hub opening is big enough to fit our front hubs - unlike the 2010 Tundra wheels. The only problem I would see is finding a color matched center cap that fits over our front hubs.
I thought the Tundy 18's were a direct bolt-on (with the exception of the front cap)? Now I'm concerned 'cuz I've been looking for some of those on CL!
But, ouch! $750 for OE takeoffs!
The original Tundra 18" Alloys (2007+) fit perfectly as they have the large hub opening. I have seen a few of the new 18" and 20" rims (maybe 2010 or 2011) that have really small cutouts for the hubs and those will NOT fit the 100 series unless you use a spacer.
nice, didn't realize 200 series have 17" rims, read somewhere back it might have been geared for Canada as a lex opt equip wheel, thought cruisers only came in 18's... I'm pretty sure those are a direct bolt on, I have a 470 with 18" 2010 cruiser wheels on, it's a direct fit, no spacers, center caps from my 98 also fits perfectly, the finish is also comparable as well. As for cruiser center caps on those, it seems pretty similar to mines, i think it might fit as well....
Good to know 200 series will fit:clap: Now to find out if there was an option for 17" on the 2010 200 series.
Looks like I need to venture over to the 200 board:grinpimp:
From what I know, those will definitely fit.
I KNOW the 17" are standard, and the 18" are "options" but basically every truck in NA came with the 18s.
Same story pretty much as the 2003 100 series. I will find some 17's some day hopefully less then $750 set:rolleyes:
...I will find some 17's some day hopefully less then $750 set:rolleyes:
In Oz, Toyota stocks a steel 17" rim for the 200 that fits the 100 for about A$130 each. I got one as a second spare as I can't find an alloy to suit my existing rims, but the steel rims are heavy.
All 2007-2009 200's in Oz got 17" rims, 2010 models are using 18" on the higher spec models, but they're all (alloy rims) going for plenty of $ on the 2nd hand market.
