"Keep in mind I have not a clue of what I am doing. Every time I fire up the cutting tool I crap in my pants. Will I cut something out that makes the truck blow up? Is this whole thing going to fall apart if I remove the quarter pannels? I figure as long as the welder keeps spitting the wire out, I have a fighting chance on getting this thing back to life. "
I feel in the same boat sometimes.I have been messin around welding as many things as I can before i start on the lv.
I did follow Matt's lead and am painting everything inside and out with an epoxy primer. it seems to bond to the metal almost like the old boat finish "Imron". i am tring to spray it in as many areas that I can get the spray gun into but some of those areas like the inside of the doors, are only getting wire brushed and prepaint solvent wiped before the primer goes on. but i feel atleast its something.
Where are you moving too? if to a coastal enviorment, and you plan on using por-15 I would use it in your current enviorment now before you move I have not had much luck with it in a humid coaastal place.
keep the pics coming I will hopefully have the rest of my lv home by christmas (time) and will start postig pics as well
HTH Jason
HTH Jason
