1hz turbo camshaft
i am curious, has anoyone ever actually SEEN the factory 1HZ-T engine in real life? if so is the turbo factory equiped or is it an aftermarket turbo installed at the dealer level?
anyone have pictures of this rare beast of an engine? i would love to do a side by side comparrison with a HDT...
cheers
Well Ive asked for some proof outside of Engine Australias catalog at least 3 times and it has not been forth coming.
As I said before ,you search on google and find info pics,anything about Toyota diesels.
Except the mythical 1HZ T
How many workers at Engines Australia are running factory built 1HZ Ts?:rolleyes:
i am going to install total seal gapless 2nd rings in this engine too, the part number is #208722 this is an individual ring number for a 0.5mm oversize cylinder. less blowbye more compression sealing= cleaner oil and lower oil temp, less oxidation, dilution, soot levels.
use google to get you to the actual web site then see for yourself, still trying to clarify the required honing pattern to keep this ring happy. std engine requires, as i am told by my machinist, a 400 grit hone with a coarse bubble hone after that. sort of a reverse plateau hone.
does anybody have any more correct/conflicting knowledge on this one?
thanks for all the input on the camshaft question, particularly Dougal the fellow from NZ about the turbo sizing, much appreciated. also the decoding of the multi valve engine models.
maybe they are all pulling my leg, i told them what i was trying to do, they suggested using the 1hz-t pistons, from the bus, (not the first place i have heard it either, really i don't care, the pistons i am buying from a non glamourous source at $90.00 each have all the features we want to push more torque through this engine. i asked it before but got no answer, how much are people paying for these "custom" 1hz turbo pistons, i enquired about some through a guy who was importing them from england, he wanted about $2600.00 for six pistons and 1hd-t rods, the rods are $280.00 new each. as i have heard the odd american say on the television, "you do the math"
to the bio diesel and waste vegetable oil in di or idi engines......i believe they both run well on the alternate fuel. the consistancy of home made fuel, or fuel made from less consistant ingredients, may not be as consistant as the store bought aussie light crude we purchase as diesel. we have all heard of the bad batch of fuel stuffing things up? no? well you can be lucky and just get the bacteria that lives on the miniscus between the water in the bottom of the tank and the fuel (its black and slimey), this just costs a half dozen filters and some chemical. real tainted fuel may stuff the inj pump and or injectors. if this is more likely to happen whilst using home made or less consistant fuel, the cost of a set of 1hz injectors is about $350.00 exchange for a set of six. a mate of mine had a landrover 5 cyl diesel which he sold because the replacement injectors he needed for it were in the order of $2500.00. the point i am making is that if it happens every two years and you do 30,000km per year. over the life of the engine, 500,00km, it could cost an extra 8.3 by (2500-350=2150)=$17845.00 in maintainance costs. i have access to a pop tester and wet and dry sandpaper, new pintle nozzles for the injectors are about $25.00 each. brand new injector pumps can be had for about $1600.00.
i can live with the heightened probability of fuel induced pump and injector maintanance costs, traded off against cheap fuel(also environmentaly sustainable), when the limits of these increased maintanance costs are kept in check with cheap parts.
further to this, simple, low pressure, indirect injection diesel fuel systems will tolerate more variance in volatility, lubricity and residual deposits than a direct injection fuel system, let alone a common rail with 20000psi injection pressure.
so this is what i am getting from this paragraph:
there are special factory pistons for the 1HZ-T turbo but nobody knows the part number.
you can get the same cool ass pistons from a jobber for $90
even though these are used in Oz you have to buy them from "a guy" who is bringing them in from England for $2800 (with rods). (why do you have to bring them in from England)
now if i was making a claim or a shop i was working with was making a claim of some non-existant engine or special pistons i would be asking for the part number, calling toyota Oz and asking for a part number and a price...you can probably get these same special pistons from Toyota for hte same price and save shipping costs.
sounds like you are being fed a forkfull of special Oz sheep s***. get a friggin FACTORY part number so we all can share in this dream of yours.
Please read what i actually wrote instead of a jumbled mix of details arranged to provoke argument.
1. the guy (from some garage in ipswich) who's details i didn't record as he wasn't offering me anything competitive, was able to get the custom piston/rod kit from England for $2600.00.
2. Engine Australia phone No; 1300364463
3. Ask for Craig Fermor
4. refer to my quote to supply parts No QDAL30521 from 03/05/07
5. above the item it states "this is a genuine Toyota part"
their part No is POTO 340 STD
their description is TO1HZ-T PISTON ONLY
qty 6 $90.00ea gst $54.00 sub tot $594.00
6. the part number may be theirs for their system and not a toyota number, i am not sure and i don't care, after you ring them (on your telephone) you can ask them, as i have said they are very helpful and i can only recommend them in the highest regard on anything to do with engine spare parts.
hopefully this will quell the malcontent over the imaginary engine, mind you none of the other evidence provided has....does anyone here get off on creating myths?
i just want to find useful info from folk with a common interest and share what i have found where it might help others....isn't that what these forums are for?
i hope you don't have the same issues with the easter bunny or santa conspiracy theorys!
LOL!!
you related to Roverboy?
"i didn't record this and that." because "i am not sure nor do i care"
WOW!! i love the facts about this mysterious engine and engine parts. you are right there and they are you buddies but you don't care enough about the mud members reading this thread to validate your claim that there is such parts available from Toyota...well, why would anyone believe you??
i have the factory EPC sitting right here and (are you listening??) THERE IS NO FACTORY PART NUMBER for such an elusive engine under coaster bus.
it is right up there with the Easter bunny and Santa and the beleif that Elvis is still alive and kicking.
but if you beleive it then it must be true...even with out any facts to back it up.
as soon as i get the pistons i will put the numbers off the box on here, i have given all the information i have on it including the contact details for you to validate it directly.
i guess they will come in the genuine box being genuine parts
is EPC electronic parts catalogue?
can the public access this online?
goto http://www.engineaustralia.com.au/ then technical then engine specifications then toyota then look through the list, it is there...1hz-t
hi
I have a 1HZ dts turbo water/air intercooler 3" exhuast on my 80 went really good. It know has a lot of blowby looking at a rebuilding soon. Very interested in what you are doing . Just started doing some research into pistons , conrods etc
I known the 1HZ T was listed on their site for a long time after someone else pointed it out to me.
Ive since seen no other mention of it anywhere
Also the 1HZ T is a dead link. All the other Toyota diesel specs are available for perusal.
Maybe people have been ringing up asking questions and EA have gone away and checked on the authenticity of the 1HZ T.;)
Their site claims to be republishing the information from OEM parts manuals.
I bet they got their info from the same place hdj105 Greg was looking at and have realised its incorrect.
buds, before you go rebuilding your turbo engine...
?does it have blowbye? or is the slight increase in crankcase pressure combined with high intake vacuum, sucking the oil from the tappet cover vent into the turbo inlet and giving the appearance of blowbye?
do you have your oil sampled and lab tested?
oxidation& maybe fuel dilution will be high if this is the case.
how is starting, oil consumption, power, fuel consumption????
....have you had your pistons in a plastic state through heat?? does it sound slappy at all?
i have been drawing up a plan for a reticulating catch can, nothing new, crank vent goes in the bottom, through a column of ENTRAPT stainless steel wool, out the top into the turbo inlet, SMALL drain off the bottom goes into the sump via the turbo drain (use a T piece)..make the can out of 2"pipe, mount it near the air cleaner perhaps, someone else had pictures of an air2air cooler with one fitted on an 80 series.
rosco, maybe it is a myth, even if so, the pistons with the goods at that price are worth letting people know about don't you think?
i started this thread to find info on cam specs and it has gotten some distance from there, i will contribute anything i find out for the good of the forum (people)
the link for the 1hz-t is black instead of blue, like a few other engines on that page yes
seriously, many of us cruiserheads have developed a deep knowledge of the Toyota engine series. if something new is found we all get excited but if we can not find backing for the new knowledge then there is a let down experienced.
also, if a company claims something is "factory" and it isn't, even if they are the friendliest blokes on the planet it makes us question the validity of other claims on the site.
yes, if there is a cool set of pistons, crank, cam etc for the diesel engines that we drive then it is great that you let us know about it. most of us like stock settings but there are a few of us adventurous types that to try new ideas or read about others "test runs".
i still do not beleive that the 1HZ-T is a factory engine BUT i am interested in your engine build. keep us updated on your progress...
I got nothing against cool new products and I whole heartedly endorse the spread of information:D
Like Crushers said ,many of us have a deep knowledge of Toyota products and when something new comes along it makes us blink and want to learn more.
When we can find no evidence except a dead link on an aftermarket engine parts suppliers site we get a little suspicious;)
(the link is black because its dead)
LOL!!
Wayne, I suggest you brush up on your EPC skills ;)
Here's the part number print out for the 1HZ-T pistons, showing the part numbers.
There's so much testosterone flying aroung this thread it's not funny!
well, blow me down...lookie here someone found the elusive proof the engine exists!!
now i am a believer... a born again HZT convert...
THANK YOU!
<see push a bit and someone will prove it or not.>
now, does anyone have the pics of an existing engine?
cheekyboy31, nice to have someone backing you up, eh?
Is that an excerpt from a Toyota EPC or Engine Australia catalog?.
Wheres the HDB50 (1HD T powered 50 series Coaster)from the same year?
Cheekyboy31
When removing the breather tube from the turbo intake, after a run it appears very smokey and breathing heavy. It does feel down on power. Does not seem to be using oil.
No i have not taken any oil samples. maybe i should next service.
I had purchased an oil catch a 2 weeks ago from Super Cheap Auto about $60 just have not had time to fit it. I like your idea of returnig it back to sump.
i doubled checked his EPC post with my own and unless Toyota inserted the wrong designation then well... it does exist.
BUT
i would love to compare the pistons stated with the HDT ...
now why don't i do that:
well, Rosco... i crossed the part numbers between the 1HZ, the HDT and the 1HZT and the pistons for the 1HZT is a unique part number...
BUT
Ye of little faith... :rolleyes:
I did mention all that in my post (#32) above (in which I displayed the engine decal illustration - that wouldn't be a misprint!.
The pistons are unique, the rods are 1HD*, I didn't check the rings but as 1HZ and 1HD-T run the same rings I'd guess they will be the same too. If you check the turbo part number you will see it's unique to this application too.
I wasn't aware of the 1HZ-T either until I checked after reading the start of this thread, and I like to think I know everything 'Cruiser too. When I checked the EPC I got the suprise too.
We just need someone to take a picture of a real one, and apart from the fuel pump & injectors will externally look just like a 1HD-T anyhow.
Buds,
maybe a compression test to back up the probably reliable hunch, does it start well?
hdj105,
what is this EPC? can i get access to it? or do you have to work for toyota to get access?
