1HZ Oil and Coolant Sensor Locations?
In the MUD...OUTSIDE the box
The 1HZ has various (3-4, I can't remember) sensor locations on the lefthand side of the engine block.
I need help identifying what the locations are for:
--oil pressure
--coolant temp
Pics would be the best.
Thanks in advance!!:cheers:
far left in this pic ( actually half cut by the pic ) it's the cooland sensor .. or at least one of those ..
main.php
Found the coolant sensor location, thanks Tapage! Mine was plugged with a bolt.
Found the oil pressure sensor location, thanks Foreal! There is a coolant drain just above it.
To the left of the oil filter, there is a sensor in the alloy housing. It has a green coating and two wires (yellow and brown). What is that for? :bang:
To the right of the oil filter high up in the head, there is a sensor in the rear half of the engine. It has a brown coating and a one wire female connection. What is that for? :bang:
:cheers:
What year is the engine and where did it come from?(did I ask you this before?) The aussie models from the 75 series have a coolant sensor on the coolant outlet.
The one you are mystified by maybe a sensor for the glowplug timer.Glow time is related to engine temp
