SOLD 1HZ fan shroud
Mount Pleasant, SC
Who's got one? Going to Mt Pleasant SC. pn# 16711-17020
Gracias
This for a 1985 radiator with a 1HZ transplant. substitute part number 16711-17090.
@SNLC can you shoot me a picture? And how much?
Has some rust on the bottom
Nothing that can’t be painted! Pm me with details. Thanks!
And thank you! It will fit the radiator perfectly. Unfortunately the fan doesn’t line up because I installed the engine too low. Need to raise it 2-3”, which will screw with all my other connections. An expensive and time consuming mistake.
Lesson learned: when changing engine models, step one is buy a shroud with the engine. The trans sits in the same place and the engine mounts are asymmetric so the shroud is a locator tool.
