1HDT / ZF 8HP Swap – Adapter Design & Fitment Checks
Indonesia
First time posting here, just wanted to share what I’m currently experimenting with. I’m building a custom adapter for a 1HDT to ZF 8HP swap, fully designed and machined in my own workshop. Still validating clearances and tolerances before final assembly. Any advice or common pitfalls I should watch out for from those experienced with 8HP swaps?
Yes please. Now this is a beautiful swap.
I've just discovered this thread. I have a 1HDT that's had a major turbo upgrade, and the transmission is now the weak link - they told me that they had to detune it a bit because the torque converter was struggling to lock up with the extra torque.
It had never occurreed to me tto upgrade the transmission.
So many questions. I don't suppose anyone makes a kit for this? Also, pardon my ignorance, but what happens to the transfer case?
TIA
Sorry about this dumb question but i see manual shifting. I'm assuming this is Manual mode just for fun and you can set it in Drive and let it do its thing? I realize the bugs are still being worked out.
Not a dumb question. Yes the ZF 8HP has a mode where you pull shifter to the left and it goes into sport/manual mode. Or you can leave it alone and just drive it like a regular automatic.
TIA
Yes, there are adapters to mate the ZF 8HP to a 1HDT and also to mate the other end to a H2FA.
Thanks but what is a H2FA? ChatGPT was no help
From ChatGPT:
The HF2A transfer case is a well-known, heavy-duty 4WD transfer case made by Toyota. It’s most commonly found in older Land Cruiser platforms—especially relevant given your 80-series.
What it is​
The HF2A is a full-time 4WD transfer case with a center differential, meaning:
  • You can drive in 4WD on pavement safely
  • Power is split between front and rear axles automatically
Where it’s used​
You’ll find the HF2A in:
  • Toyota Land Cruiser 80 Series (your rig)
  • Some Toyota Land Cruiser 100 Series (with variations)
Key features​
  • Full-time 4WD (no need to “shift into 4WD” for normal driving)
  • Center differential lock (manual or electric depending on year)
  • High and Low range
    • High: normal driving
    • Low: off-road / crawling / towing
Gear ratios (typical)​
  • High range: 1:1
  • Low range: ~2.48:1
Why it’s respected​
  • Extremely durable (classic Toyota overbuilt design)
  • Handles heavy off-road use and big tires well
  • Smooth on-road behavior compared to part-time systems
Common quirks / issues​
  • Center diff lock actuator can seize if not used regularly
  • Leaks from seals (age-related)
  • Needs periodic gear oil changes (75W-90 typically)
Practical tip (for your Land Cruiser)​
If you’ve got an 80 series:
  • Use the center diff lock occasionally to keep it from sticking
  • Engage low range once in a while even if you’re not wheeling
If you want, I can go deeper—like how it compares to part-time cases, how to service it, or mods (like twin-stick conversions).
Are you planning on selling this adapter? This trans swap would really breath new life into my 1hdt 80
From ChatGPT:
What it is​
Where it’s used​
Key features​
  • High range: 1:1
Why it’s respected​
Very useful. Thanks. I found a place in Australia that sells the adapters - now I have to find a place that can do the cpnversion
Excellent! You're the second person/shop who does this conversion. The first shop I've come across is in the Netherland, called Wink4x4. Glad to see another for sure.
