Hi all
I’m replacing the sump on the 1HDT in my HDJ81. It’s started to seep between the block and the pan, and the threads on the drain plug have been badly repaired via helicoil and oversize plug by the PO – when I do oil changes my spidey-senses tingle when tightening up the plug – feels like it’s on the verge of stripping.
The pan has been off before (someone did the BEB and resealed it with the grey RTV).
I know this is a simple job, but are there any tips or tricks you guys can share about doing this job? Know the hardest part is getting it off.
My plan is
Get pan off
Clean block, removing any old RTV
Clean all the fasteners and holes
Lay a bead of sealer on the pan and block
Put the fasteners in finger tight
Let sealant go off for an hour or so
Do fasteners up to half torque spec
Leave it overnight and then torque to spec.
Thanks
My plan is
Get pan off
Thanks
