1HD-T Intake Manifold Modifications (1 Viewer)
Never enough :). You can't do the intake mods to the ft anyway.
I know it's old.
But read the thread from the beginning.
Why do you not think the FT manifold can be modified?
Or do you think there is no reason to modify it?
I seemed to remember that some people think that there is no room for the rigid ignition cables / pipes.
Those shall be redone anyway, as I plan to switch to an inline pump.
The FT/FTE manifold can be modified for improved performance but most people don't bother due to the injector lines going over the top instead of between the runners like on the HZ/DT. I've seen a few who kept original injector lines and either used internal passages in the plenum for them to pass through or modified the plenum in the areas either side with dual entries etc. But the better designed ones all need to have new injector lines made to suit so they don't have to compromise on the ideal inlet design
