Looking at HF 2-ton crane and stand. Overbuy and understress. Good reviews from Mudsters.
If I wind up with HF, I'm not gonna be able to check that until it's home and out of the box. I'd buy something triple the price if I could but...priorities; it won't see a lot of use. (And for all I know the name brands are the same damned thing these days.) There are some rehab candidates on craigslist, but most don't fold, and who knows what kind of weight they've had on them. Old wrench, fine. Old something-I'm-gonna-hang-500-1,000 lbs on, not so much (unless its ridiculously overbuilt). Thanks for the CG tip; guess that's why I saw a cement bag on the crane base in one of these threads...Can you physically check it out?
The generic Chyna one I bought has way too much slop in the folding legs.
It's because the pins and hole placement is loose for easy assembly, but that looseness makes things a bit of a pain while using it
And castors are s***, even after greasing them
Otherwise, it's all good.
I agree on the over buy idea. Get one with a heavier rating, and longer legs.
The Toyota engine is heavy, and being an Inline 6, the weight is offset further than if you were lifting a big V8 because the block is quite a bit longer. It pushes the COG right to the end of the legs if you're lifting with the arm at max length.
How hard? Any tips? One-ton doesn't fold, has smaller safety margin; will go with two-ton if that'll work. Don't plan to be doing this often...I use the HF 2 ton... Also I bought the 2 ton stand and it’s a pain because the legs hit the hoist legs and make it hard to marry up...
That's exactly what worked for me. I tried the smaller one from HF and it wouldn't go far enough into the engine bay. You'll also need a load leveler. get the best one you can afford. Mine is from HF and was barely up to the task. I basically had to shoot grease on the threads multiple times and suffer with a handle that was too wimpy.Looking at HF 2-ton crane and stand. Overbuy and understress. Good reviews from Mudsters.
Sorry 1 Ton stand. Then I put purchased the 1/2How hard? Any tips? One-ton doesn't fold, has smaller safety margin; will go with two-ton if that'll work. Don't plan to be doing this often...
I've still got a Trans-Dapt leveler from my Ford 460 days; should do the trick.That's exactly what worked for me. I tried the smaller one from HF and it wouldn't go far enough into the engine bay. You'll also need a load leveler. get the best one you can afford. Mine is from HF and was barely up to the task. I basically had to shoot grease on the threads multiple times and suffer with a handle that was too wimpy.
Too bad you're not in my neck of the woods, I'd let you use mine.
As much as I hate buying made in China... The 2 ton didn't have sloppy legs at all. But you will need to extend the boom, in fact I went and hung the chain out past the pin to get an extra inch of reach. Now I use it to move heavy stuff into the bed of my Taco, on occasion.How hard? Any tips? One-ton doesn't fold, has smaller safety margin; will go with two-ton if that'll work. Don't plan to be doing this often...
The two-ton stand has two long legs. I never thought about interference with the crane legs...Sorry 1 Ton stand. Then I put purchased the 1/2
Ton Stand and it worked fine it flexes a little just don’t go crazy and it’s plenty stable.
Thanks for the illustrated reply! That’s quite a droop for <500# on a double-braced two-ton stand. Would you trust it without the braces, or were you pushing the limit with something else?I found the same thing with my gear too.
It made things a bit awkward, but not impossible.
I had to brace my engine stand, and will brace the rotating top portion before using it again.
The I6 is too long, to much leverage.
