Nope but for sure their corresponding seals
forum.ih8mud.com
Interesting thread, thanks! But no dims for the FZ crank. Same for another thread titled '1FZ crank pulley dimensions.' And so it goes...@landtank may have some input
Here's a previous thread discussing pulley sizes:
Small alternator pulley
The battery always seemed low on my 1993 since I don't drive it very far. So I made a new smaller alternator pulley to keep the alternator rpm's up and thus the possibility of putting out more amps at lower engine rpm's. In making the pulley this small, I felt there was not enough metal left to...forum.ih8mud.com
Yeah. Aftermarket alt maker looking for a diameter to work up a power curve, but I don't have a tool that'll measure it...
Outer and the grooves where the belts run, which is the actual working diameter. Calipers or careful measurement with string or wire, if someone happens to have a de-belted pulley handy…Got a sketch of what they need to know?
Is it just the outer diameter?
| DAYCO PB1413N Specifications | |
| Bolt Hole Quantity | 2 |
| Counterweight Balance | Neutral, no counterweight |
| Crank Bore | 1.497 in. |
| Crank Bore | 38.01 mm |
| Crank Trigger/Exciter Plate | No |
| Hardware Included | No |
| Installation Instructions Included | No |
| Nose Outside Diameter | 2.052 In. |
| Nose Outside Diameter | 52.10 mm |
| Number of Integrated Pulleys | 3 |
| Outer Ring Material | Grey Iron |
| Overall Outside Diameter | 6.930 in. |
| Overall Outside Diameter | 176.00 mm |
| Overall Width | 3.111 in. |
| Overall Width | 79.00 MM |
| Pulley 1 Number of Grooves | 1 mm |
| Pulley 1 Outside Diameter | 6.930 in. |
| Pulley 1 Outside Diameter | 176.000 mm |
| Pulley 1 Type | V-Belt |
| Pulley 2 Number of Grooves | 1 mm |
| Pulley 2 Outside Diameter | 6.930 in. |
| Pulley 2 Outside Diameter | 176.000 mm |
| Pulley 2 Type | V-Belt |
| Ring Width | 2.441 in. |
| Ring Width | 61.98 MM |
| Timing Marks | Yes |
| Woodruff Key Included | No |
Thanks! Confirms @mudgudgeon's work above. Interesting that it says three pulley and only specs the two we need. Still don't have the PD measurement pointed out by @mudgudgeon: diameter of belt on pulley. Can anyone measure that--or an actual belt from 'top' to 'bottom?' Anyone have a new belt set sitting around...? @NLXTACY, perhaps? We could get an approximation of the the pulley's inner diameter if we had an accurate measurement of an alternator belt, and the space between the belt top and the pulley's outer edge (assuming the belt bottoms out at the pulley's deepest point).Forgot about this, Rockauto sells a crank pulley that is identical to the original
1997 TOYOTA LAND CRUISER 4.5L L6 Harmonic Balancer | Shop Now at RockAuto
Engine Parts and More for Your 1997 TOYOTA LAND CRUISER at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.www.rockauto.com
Pulled from that website:
DAYCO PB1413N Specifications Bolt Hole Quantity 2 Counterweight Balance Neutral, no counterweight Crank Bore 1.497 in. Crank Bore 38.01 mm Crank Trigger/Exciter Plate No Hardware Included No Installation Instructions Included No Nose Outside Diameter 2.052 In. Nose Outside Diameter 52.10 mm Number of Integrated Pulleys 3 Outer Ring Material Grey Iron Overall Outside Diameter 6.930 in. Overall Outside Diameter 176.00 mm Overall Width 3.111 in. Overall Width 79.00 MM Pulley 1 Number of Grooves 1 mm Pulley 1 Outside Diameter 6.930 in. Pulley 1 Outside Diameter 176.000 mm Pulley 1 Type V-Belt Pulley 2 Number of Grooves 1 mm Pulley 2 Outside Diameter 6.930 in. Pulley 2 Outside Diameter 176.000 mm Pulley 2 Type V-Belt Ring Width 2.441 in. Ring Width 61.98 MM Timing Marks Yes Woodruff Key Included No
IF the belt bottoms out in use, then measuring the belt depth in free space on an installed engine will give us the number to subtract…
Mmmmyeah. Apparently it's not as simple as I thought. I keep seeing illustrations like these. Lemme ask the guy if he even needs this spec; maybe this is a rabbit hole we don't need to go down...The belts sit flush with the outer edge of the groove, they definitely should not bottom out in the groove.
There's a polished wear mark that shows the belt contacts the first 5/16 of the groove. (Darker line in the pic above).
I'm unsure if the pitch diameter is measure at the outer edge of the belt as it sits in the groove? Or centreline of belt etc
I would think at the outer edge of the belt, as it's the circumference of the belt.
That would make the pitch diameter same as OD in this case.
P/N 04111-66061: You've got front and rear main seals in there, right? @davidp14 @SNLCView attachment 3190706View attachment 3190705
Has hg if it's this part #
This is a great thread btw. Lots of useful info
What does it do to displacement if you bore out .5?
Gotta wonder how that translates to torque and ponies. .934% gain!It would take engine displacement from ~ 4.476L to ~ 4.518L
