ok, i have seen this posted a bunch but i want a real answer. can you take the OBD 1 setup and simply swap the pan and harness or must you swap the crank? some people say its harder than that and others say just swap the pan and harness.
does the OBD1 crankshaft have the tone ring on it is the real question. is it made onto the crank or is it pressed on if the early engines do not come with it.
i have 3 OBD1 engines sitting around but not the OBD2 style. if i take the time to tear the bottom end off of one and take pics can someone do the same on the OBD2 style for me so we can compare??
