Ok, so I have searched and searched here and other places on the web looking for an answer to my questions and can't seem to find it, forgive me if this has been asked and answered, here it goes...
I have a 1998 with 143,500 miles on it. I just did an oil change and I wanted to do a transmission fluid change also. I have a 100 series manual that I use to walk me through different maintenance but in the manual it talks about the transmission being sealed and how to check it with the two different plugs underneath, and needing WC fluid. Now I am not a mechanic by any stretch but there are two dipsticks in the engine compartment, one is labeled engine oil and the other has no label. It is just to the rear or the oil dipstick close to the cab and appears to go down to the transmission. I am assuming that this is the transmission dipstick, is this correct?
Also when I look for what type of fluid to add to the old girl all I keep running into is put WC in it or genuine toyota fluid or something like that. Is there anyone out there with a same year or similar that has done a fluid change on the transmission and what type of fluid did you use? Is this fluid available at auto zone or advance?
I have a long trip coming up, Maryland to Alabama and I am taking the LC. I don't have time now to do a full flush and replace so I was thinking of doing just a drain and replace. Again this is assuming that I am looking at the truck correctly and seeing the drain plug and the dipstick. I want to do a full transmission filter change but I have a lot of rust underneath, the truck came from PA, and I am worried about breaking bolts like has already happened when taking off the shield to get to the oil filter and taking off the running boards. I will post some pictures when I get a chance. Thanks in advance and I hope all of this made sense.
. My transmission shifted noticeable better with the Mobil 1 full Synthetic multi-vehicle ATF. The viscosity is a bit higher than Dexron II thru VI and may reduce MPG just a tad. The new Dexron VI multi-vehicle ATF is a blend.
