- Year
- 1997
- Vehicle Model
- 80 Series
- Location
- Harrison, Tennessee United States
- Mileage
- 372228
1997 Land Cruiser. I am the third owner of this truck and picked it up in Early 2023. This car lived all its life in Texas prior to moving it to TN. This cruiser currently has 372,228 miles on it.
The previous owner performed the following
Paint was corrected in 2019
Brake pads, brake booster and rotors installed in 2020
Motor was rebuilt(regasked) at 200k miles and peasky heater hose installed
Maintenance
What I have performed and can provide on an excel sheet:
Oil change
Hood Strut
Air filter with OEM washable
Valve Cover gasket
Spark plugs and wires
PCV valve and grommet
Idler pulley, power steering pump and all 3 belts
Power steering high pressure hose
OEM Alternator
Denso Remanufactured Starter
Transfer case Oil
Front and rear diff oil
Replaced all plugs with magnetic
New Venom Power Terra hunter at 372,005
Driver seat gears with gamiviti and metal brackets from ASR
Hudd Expo EGR temp sensor test plug kit
CDL new switch installed, light is not illumination in dash
MAF sensor cleaned
Fuel relay Assembly replaced
Replaced door water seals
Replaced windshield washer reservoir and pump
The Good:
Clean non rust 80 series
Previous owner kept maintenance up on it
Sunroof doesn’t leak
90% of baseline is complete
The Bad (trying to be 100% transparent):
Small dent on the tailgate
Leak on the transfer case
Windshield has chips and cracks
Driver side headlight has a chip
Airbag light is on
4wd light won’t come on.
Some paint on the carpet that I haven't had time to see if it would clean out.
Will give all parts that I have with it. This includes the airbag module, abs module, CDL actuator, fuel pump sock filter parts, charcoal media. And some more stuff that I can’t remember.
Two accidents are on its history. One in 2015 and the other in 2017.
Looking to get 9K obo.
Maintenance
Oil change
Hood Strut
Valve Cover gasket
OEM Alternator
Transfer case Oil
MAF sensor cleaned
The Good:
Airbag light is on
