SOLD 1997 LX450 BUILT, CLEAN, RUST FREE. 142.xxx miles
1997 LEXUS LX450
142.xxx MILES
VIN # JT6HJ88J8V0174585
PHH
FHH
VALVE COVER GASKET
SPARK PLUGS & WIRES
BELTS
U JOINTS
COOLANT SYSTEM FLUSH
DIST O RING AND SEAL
MODDED BLUE FAN CLUTCH
DIFFS / TRANSFER / TRANS OIL FLUSH
FRONT AND REAR AXLE GASKETS AND BEARINGS
All of this completed less than 5000 miles ago.
All electronics works, drives great.
Every panel of the vehicle was removed for paint job; welded molding holes and then whole vehicle was primed.
Sterling gray metallic on satin clear coat finish. All door jambs were included on paint job, hood breather was included at the time with shinny black finish on center of hood..
ARB front bumper with 10.000 pound SUPERWINCH (comp spec) with synthetic line and wireless remote; rock sliders welded to frame, fenders and 1/4 panels armor integrated with roof rack and rear steel bumper (Roof rack is not part of the body of the car, is part of the cage).
Voltage reader on center console.
Carpet removed and sprayed LINE-X floor.
No rust on this vehicle.
ARB diff, trans and transfer case breathers.
EGR disabled by resistor mod and ABS disabled.
CEL comes on and off for 02 sensor.
Toyota grill / Toyota headlight conversion with DEPO glass headlights.
ARB SAFARI Snorkel.
Inner fuse block for all inner and outer accessories.
CB radio setup with inner speaker.
OME J SPRINGS on 4 corners and OME L Shocks all around. 1.5" spacer up front for level stance. Sway bars extended, rear panhard leveled and LANDTANK front control arm bracket for Caster Correction. Longer brakes lines.
5 315/75/16 BF GOODRICH KM2 (5000 miles on them), one still new, Black LX450 wheels.
Bigger battery tray for group 31 battery.
52" LED BAR on roof and LED cubes on cowl panel and roof facing the rear.
USB ports all around vehicle and REAR drawer system with slide for cooler / fridge.
Clean Carfax and great service records from Lexus (24 pages). If you want a copy of the Lexus history i can send PDF file or check with the VIN number in Lexus page.
Steering wheel leather shows age.
Seats and dash are in great great shape.
$16750 OBO
This just popped up on eBay. Is it sold? I’m interested if not.
Hello sir.
Yes, deposit have been received and negotiation / pick up process have been started. Until then, is being hold.
It is on EBay, they are not letting me close the item because it have offers on it. Both mayor bidders are aware of the situation.
Thank you for your interest!
