1996 Land Cruiser EV Conversion - EVJ80 Project
Started final assembly of the battery yesterday. Hoping to finish today.
Hey will it be sort of easy to remove the pack if you have to replace individual modules ? Had to repack my 2008 Camry hybrid
It will be possible but not easy. All the rivets will have to be drilled out and the sealant broken and then the box will have to be taken apart. I built this box with the plan that it will last the lifetime of the battery. Lithium batteries are like living creatures; as soon as they are born they start dying.
Spent all day today and got one panel done haha. Going slow because it was the most important panel. Got all my wiring complete and 366v measured at the contactors! The BMS must be wired correctly because it is plugged in but it's not smoking! A good sign!
The contactor box bolts on to the aluminum side panel.
Panel on, riveted, bolted and sealed up:
WE'VE GOT VOLTAGE!
WE'VE GOT VOLTAGE!
I love the added touch of the gloves!
Great build, thanks for taking us along.
Is there a need for some type of vent on this battery box, or is there some openings to let things breath with hot/cold or altitude?
I would think gloves would be mandatory with 366 volts.
I usually just lick my fingers and give 'er a quick look-see. If my hair stands up I know everything's connected. Hard to get the hair to work right when wearing gloves. YMMV. :D
Like I mentioned earlier- I’ve repacked a hybrid battery pack and over time it’s a game of whack a mole with replacing individual cells. That’s why curious minds are wondering if care is being given for if the pack needs to be serviced down the road.
Bite that tongue. Ask the wrong questions and you'll find yourself downthumbed. 🙄
Any reason for making the battery practically unserviceable without cutting / drilling?
Keeping the battery safe and secure is the most important thing. Both from a safety (fire) aspect and for the life of the battery. There is no maintenance to perform. Water ingress or damage to the cells or shorting of wiring etc is the enemy. OEM lithium batteries are sealed up tight in a steel can as well, so I did my best to imitate it.
@lp2k your Camry has NiMh batteries which are old but tried and tested technology that last a long time. Guessing your Camry also has 150k+ or more miles by now. Lithium batteries just don't last that long and they generally don't fail early unless they are damaged or overheated. There is a very small possibility that one or two or my cells starts to fail or has some issue but it's not likely. Nissan manufactures these batteries to very tight tolerances and part of the reason I chose a 2017 30kwh is because it has the most robust and reliable chemistry and build process so it should last the longest. Basically if I have to replace one cell, I'll likely have to replace the whole pack.
I have a hole for a small IP68 waterproof vent breather (like this: 10Pcs M121.5 Nylon Waterproof Air Vent Valve, Screw In Protective Vent Plug E-PTFE M5 M6 M8 M10 M20 Plastic Breather Vent Valve (Color : 10PCS M20X1.5, Diameter : With nut, Height : Black) - - Amazon.com - https://www.amazon.com/M121-5-Waterproof-Protective-Plastic-Breather/dp/B09M7ZMRN1?keywords=nylon+vent+valve&qid=1639703309&sr=8-2&linkCode=sl1&tag=imddd-20&linkId=88d7b38bc3dc12f772e976510afd50d7&language=en_US&ref_=as_li_ss_tl) but I'm still waiting on it to be delivered to for now the hole is just taped up.
Congrats! You've been really getting at it and getting stuff done! I hope that since you live pretty far away, you will post some video at some point.
