- Year
- 1994
- Vehicle Model
- 80 Series
- Mileage
- 188131
- Color
- Green
Hey all, I wanted to post this here before I submit it to BAT. I have sold a few vehicles on BAT and you do get "top dollar" but it is time consuming, so I thought I'd post this here first for a few days to see if a fellow Mudder is interested in a relatively quick sale. I've had this truck for just over a year and have done a mechanical and cosmetic "refresh". Mechanical work was done by an independent Toyota mechanic who worked for a dealer for many years and now has his own mobile Toyota repair service. Records of repairs will come with the truck. She's not perfect but does have only 188k, no accidents ever, very stock except for running boards are removed and has an upgraded touch screen Pioneer stereo. Ice cold (new) AC and hot heat. See pix and description below:
Amazing cloth interior seats with no rips tears or stains
Original engine w/ 188k
Original A442F transmission - heavy duty
Original Toyota OEM window glass all around (except for windshield)
Dash looks great - no cracks
New brake pads, rotors, and calipers all around
Replaced Wheel bearings
Sunroof works – Cleaned sunroof drains
New OEM crank seal
New OEM fuel filter
New OEM fuel sending unit
New OEM spark plugs, (Denso) spark plug wires, distributor, cap and rotor, PCV Valve
New OEM air filter
New OEM valve cover gasket
New AC compressor, condenser, and receiver dryer
New AC belt and serpentine belt
Pioneer touchscreen stereo and upgraded Pioneer speakers
New Aisin blue fan clutch
4 brand new power window motors
New window belt molding at base of all 4 windows
2 new hood struts
Recent Oil change with OEM filter
Solve Function shaky mirror repair kit on both side mirrors
Solve Function front end caps (covers where running board was removed behind front tire)
Three new windshield wipers
New Toyota 84 month true start battery
Radiator flushed and filled, new OEM radiator cap
Cleaned, serviced, and greased front axle/Birfield joints
New (year correct for a ‘94) center caps
Full tank of gas
Wash, wax, paint correction and carpet shampooed at local detail shop
OEM floor mats (driver's side has "heel" mark)
Original 1994 factory brochure
Clean Carfax with no accidents, clean NC title in my name
Things to know:
Faded/imperfect paint on hood and top
Couple of oil drops on the garage floor might be rear main seal seeping as many 80s do
BFG K02 tires are good for now, but might need replacing sometime soon
Power mirrors work, and adjust all ways- except side to side
Interior plastic around sunroof missing in front, does not affect operation. Also sunroof glass panel is not perfect
Asking $19,500. Truck is located in Wilmington, NC. Pls send PM - I can then text more pix
New OEM crank seal
New OEM fuel filter
New OEM air filter
2 new hood struts
Full tank of gas
Things to know:
