SOLD 1994 Toyota Land Cruiser FZJ80 185k miles. Baselined. Modded. Tampa, Florida. Red on Brown Cloth. (1 Viewer)
Year
1994
  1. 80 Series
Florida United States
Mileage
185000
Color
Red
Hey Mud Fam'.
Posting one of our 80's for sale.
Highlights:
  • 185k Miles
  • Medium Red Pearl on Brown Cloth Interior.
  • Sumo 10% Overdrive Transfer Gears.
  • 2.5" OME Lift, Dobinsons Steering Dampener w/ Dobinsons sway bar extensions.
  • TJM Front Winch Bumper
  • Kaymar Passenger Side Spare Tire Carrier
  • LT315/75R16 KM3's on LX450 Gray Powder Coated wheels. Including Spare, Toyota Center Caps.
  • Kenwood Double din unit w/ rear view camera & POLK speakers all around.
  • LED License plate lamp.
  • JDM Fender Turn / signal lamp.
  • Delta Vehicle System Ram Mount
  • BH3D Cup Holder in Shifter Console.
  • OEM OH SH*T Grab Handle Bar
  • Extended Diff Breathers
  • No roof Rack from factory.
  • No factory Lockers.
Maintenance:
Here is where this 80 excels. Everything needed have been handled. Every item have been replaced with either OEM or equal quality, mostly from mud vendors. All preventive maintenance have been completed.
  • Coolant system overhauled, from Radiator to Thermostat, Headgasket, Hoses, PHH / FHH to heater control valve. All gaskets and seals replaced alongside the Coolant Flush. Fan Clutch & Fan Replaced (Aisin).
  • Rear Main Seal Replaced.
  • Power steering hoses replaced and system flushed. Aux PS Cooler.
  • Brakes overhauled all around, From calipers to rotors, pads and EBrake Hardware. New Master Cylinder & Brake booster Hose + Valve.
  • Front + Rear Axle / Birfields overhauled with Cruiser Outfitter kits.
  • Front Track bars replaced (OEM) w/ 555 Tie Rod end kit from Cruiser Outfitters.
  • OEM Fuel Filter.
  • New battery with hold down bar and Fusible Link, Military Battery Connectors.
  • Plugs, Valve Cover, plugs gaskets, plug wires, dist cap + rotor and seals, Belts, PCV, Oil + Gas Cap replaced. All OEM.
  • Intake hose replaced alongside most rubber under hood, OEM.
  • Alternator + AC Compressor replaced, REMAN.
  • All fluids flushed; Diff plugs replaced with gaskets, Transfer case as well, OEM.
  • Ujoints greased and shafts balanced.
  • OEM vacuum lines.
  • Replaced Charcoal Canister, VC120, linea replaced as well.
  • Sway Bar Bushings and links replaced.
  • Front Control Arm Bushing replaced with OME correction bushings and OEM arm to frame bushings.
  • New Koyo Bearings installed alongside Birfield job.
AC is cold, Heat is hot, rear heater deleted. Drives great. All gauges work.
Exterior / Interior:
  • Fixed Rubber Antenna
  • New Rear Gate Emblems, OEM.
  • Refinished 4 years ago in OEM Color, Medium Red Pearl. Base Coat Clear Coat, Have not been sanded and buffed.
  • Rear Bumper refinished in OEM color as well, base coat clear coat.
  • New Wipers.
  • New Upgraded Washer Nozzles, OEM.
  • Extra Weatherstripping installed thru all doors.
  • No Steps.
  • Hood + Tailgate struts replaced.
  • Mud guards in all 4 corners, OEM
  • New Lug nuts all around.
  • New Windshield / Back Glass Weather stripping when Paint Job was completed.
  • Regular floppy AC Vents and side view mirrors. Not bad, just a bit of play.
  • OEM Floor Mats, all 3 rows.
  • Upgraded Center Console with arm rest.
  • Carpet In great shape.
  • Vehicle acquired with undercarriage coating; It was removed to review if any rust was present and was coated with POR15 3 stage process afterwards.
  • Spare Carrier is 10+ years old and works great but I add a bungee cord on the handle for extra insurance.
  • Sunroof works, all glass works.
  • Headliner in excellent shape.
  • Seats in amazing shape as expected from OEM Cloth.
Vehicle is located in Tampa / St. Petersburg, Florida.
If you're looking any extra picture please feel free to let me know.
Happy to provide extra information, open to PPI's, can help in transport.
Clean Carfax, Clean Title. Been in the family since 2007.
Asking $28k.
Thank you!
Nice truck. Why are you selling?
Man that is nice. I’m about $20k into my 91 after $7k purchase plus baselining and maintenance and while I love it, still nowhere as nice as that and have more work to do…
Great looking rig. Nice work all around
Nice truck. I wish I had the funds. GLWS.
Thank you guys!
A lot more into this one. Money it not being recovered, memories spent with her stay forever.
