For Sale 1994 FZJ80 Tripple Locked $26,000 (1 Viewer)
Year
1994
  1. 80 Series
Mileage
300400
Color
Tan
Outside Link
https://www.facebook.com/marketplace/item/23924023380624184/
1994 Toyota Land Cruiser FZJ80 4.5L i6 300400 miles
Tripple locked, clean title in hand, smogged, registered until 2026
This has been our family adventure rig since 2019. I have done a tone of mods and upgrades to make this very mechanically sound. It is a solid rig and I would drive it across the country right now. Turn key, ready to go.
Engine:
  • Engine runs strong. Great compression, good power, no smoke or burning oil
  • Head rebuild by shop in 2019
  • Pressure checked all cylinders 150 psi
  • replaced radiator 2019
  • New water pump and fan clutch 2023
  • Oil pump gasket - 2023
  • New power steering pump – 2025
  • RED HEAD upgraded power steering pump with larger input/output bearings 2023
  • Slee wiper fluid relocation kit.
  • Dual battery system with disconnect
  • Two optima batteries – start battery replaced July 2025
  • Snorkel
  • Plugs, cap, rotor, wires all replaced in 2024
  • Exhaust and muffler from cat back replaced 2021
  • New valve cover gasket and distributer gasket
  • All hoses replaced including PESKI heater hose
Drivetrain
  • Tripple locked – all actuators rebuild and serviced in 2022
  • 2.5inch lift – OME shocks with heavy duty 880lb springs in the rear. Just replaced front shocks last month.
  • 35” Milestar Patagonians, including spare
  • 488 gears
  • 3.1 transfer case crawler gears
  • Transfer case rebuilt, all new bearing / seals 2022
  • Marlin Crawler full front axle rebuilt. Bearings, seals, top to bottom 2023
  • Both front axles and birfield joints replaced in 2022
  • Marlin Crawler 1 ton steering
  • 7 pin modification – 4x4 capable in high range
  • All driveline u-joints replaced 2022
  • Complete rear axle rebuilt top to bottom seal/ bearings with 488 gears 2023
  • All brakes and rotors replaced with 100 series upgraded brake pads
  • All drivetrain bushing and sway bar bushing have been replaced and OME caster bushings installed – drives straight and smooth.
  • Quick disconnect sway bar
Interior:
  • a/c is cold and holds charge good, a/c evaporator and expansion valve replaced
  • Double din CarPlay stereo and backup camera / apple play or android play
  • Updated Pioneer speakers
  • SwitchPro – 8 position switch 6 positions left for adding electronics
  • Updated 3d printed cup holders front and rear
  • Ipad holder for navigation
  • Rear power added in center consul and doors (ashtray delete, added USB power ports)
  • Ram mount phone holders for driver and passenger
  • Dash cover
  • Rear drawer system with sleep platform
  • ARB 50-quart fridge freezer. All wired to secondary battery
  • Tailgate storage modification - hurricane fabrication
  • Corebau front seats with manual slides
Exterior:
  • Trail Gear tube front bumper
  • Smitty build 9500lb winch
  • HIR 2 Headlight bulbs
  • Front turn signal mods
  • Light bar and ditch lights
  • Rock sliders and catalectic converter skid plate
  • 4x4 labs rear bumper with swing out with table and spair tire carrier
  • High lift jack
  • Trasharoo bag
  • Custom made roof rack to accommodate roof top tent
  • Two awnings – one off the side and one out the back
Additional items:
  • Air compressor comes with sale, Smitty build
  • Extra transfer case
  • Extra starter
  • Seals, hoses, u-joints, bearings, extra dash parts
  • Lots of parts I have acquired over the years ( all goes with it)
  • 2 fuel cans and 3 water cans
  • High lift jack
Known issues:
  • Window motors are slow
  • Door panels have tears and cardboard could be replaced if wanted
  • Very slight leak from rear main seal
  • Durabak paint - I touched up hood and roof paint – I have extra paint if someone wants to touch up the rest of the body.
  • Single dash crack above driver’s cluster – dash cover now
  • Key fob just quit working – possibly the door lock brain under seat
Feel free to reach out anytime with any questions
Bryan
Its $30k
