Trade 1993 FZJ80 Factory Locked, 4.88's, OME Mediums, 35's, 137K trade for 100 Series (5 Viewers)
SOLD I have a 1993 FZJ80 that is factory locked with center dif switch out of a 91-92, Nitro 4.88 gears, OME Mediums, 5x 315/75/16 GY Duratracts with about 5K miles on them. I am looking to trade for a 100 series. There is one off road park near me and I have been there twice and have conquered it already. I have enough other hobbies that hard core traveling for wheeling is not one of them. This truck has been my DD and the rare weekend wheeling trip, it has performed flawlessly. I am looking for a nice 100 that has been taken care of, if it is a 98-99 it should have the rear locker. Prefer a 2000 or newer. I have a clean and clear title in hand. More info in link in my sig. I also had the Mikes Express unlimited works wash this winter and washed it nearly every day. Only minor surface rust on underside, nothing to be concerned with.
How I bought it. http://m917.photobucket.com/albums/...rI+gk36ROXlNwrWLqrIymx7zJIQlkrtf+gxf5l0E/3yw=
Below are my maintenance records
1993 Toyota Land Cruiser Maintenance
Date
Mileage
Maintenance
1/16/2010
129,145
Purchase
1/17/2010
129,350
Drain 4 qts Trans fluid add 4 qts mobil 1 Syn ATF
1/17/2010
129,350
Rear Diff 80-w90 + Lucas oil HD 80-w90 4 qts
1/18/2010
129,350
Center Diff Syn 75-w90 2 qts
1/18/2010
129,350
Front Diff 80-w90 + Lucas oil HD 80-w90 3 qts
1/18/2010
129,350
Add CDL Switch from 91-92 LC
1/18/2010
129,350
Armoral leather interior
1/23/2010
129,500
Oil Change 5w-30 Mobil clean 5000
1/23/2010
129,500
Filled Birfs with Moly Grease
1/23/2010
129,500
Took off running boards and old window tint
1/23/2010
129,500
Blocked EGR by routing vacuum lines
3/6/2010
130,000
Spark Plugs + Wires+cap+rotor - OEM
3/6/2010
130,000
Front Brake pads - OEM
3/6/2010
130,000
PCV valve and hoses - OEM
3/15/2010
130,200
Air Filter
4/28/2010
130,500
Leatherique all seats
8/1/2010
131,000
New VC in T-case and 4.88 gears Master bearing kit install, solid spacers
8/1/2010
131,000
Knuckle rebuild Kit Install, Syn in all difs
8/1/2010
131,000
New AC condenser, recharge AC
8/1/2010
131,000
Grease all u joints and drive shaft fittings
9/19/2010
131,200
Leatherique all seats, 303 dash
9/23/2010
131,250
OME 2.5 lift springs and OME nitrocharged L shocks
9/24/2010
131,300
315/75/16 GY Wrangler Duratrac
10/2/2010
131,500
8 qts Mobil 1, 5W-40 TDT/5 qts M1 Syn ATF, top off PS,brake
10/3/2010
131,500
Lexol seats, new air filter
1/22/2011
135,350
8 qts Rotella T6 Syn 5w-40
3/19/2010
137,100
Rotate tires
More lexol on the seats today.
Cats were blocked and have been removed so if you have smog check in your state you will need new cats.
I have 7 freshly painted center caps(4 on the truck, 3 spares), 8 toyota small oil filters, new belts, a shifter with 30k miles so no wear and an extra fuel door. Set of rear brake pads, (didn't need pads like I thought it did). I also have Man-a-fre 30mm spring spacers that I haven't put on yet. I also put together a PHH by-pass kit that I haven't installed yet. I love this truck and it runs great, but I'm more of a poser wheeler and a 100 would fit me best.
AutoCheck Vehicle History Report
1993 Toyota Land Cruiser Report Run Date: 2010-01-31 07:43:17.315 EST
This AutoCheck Score
The AutoCheck Score is a summary of your vehicle's history, letting you compare vehicles with ease.
About this vehicle's AutoCheck Score
This vehicle qualifies for Buyback Protection
Safeguard your investment with AutoCheck Buyback Protection, which reduces the risk in buying a used vehicle.
About Buyback Protection
VIN: JT3DJ81WXP0034347
Year : 1993
Make : Toyota
Model: Land Cruiser
Style/Body: SUV 4D
Class: SUV - Premium Large
Engine: 4.5L I6 SFI
Country of Assembly: Japan
Vehicle Age: 17 year(s)
Calculated Owners: 5
Last Reported
Odometer Reading: 126,800
Section summaries
The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.
Title and ProblemCheck: Your vehicle checks out!
OdometerCheck: Your vehicle checks out!
Vehicle Use and EventCheck: Specific vehicle use(s) or events reported
Full History: Detailed information available
Your vehicle checks out! AutoCheck's database for this 1993 Toyota Land Cruiser (JT3DJ81WXP0034347) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems.
0 Problem(s) Reported: 15 Title/Problem areas checked:
No abandoned title record
No damaged title or major damage incident record
No fire damaged title record
No grey market title record
No hail damage title record
No insurance loss title or probable total loss record
No junk or scrapped title record
No manufacturer buyback/lemon title record
No odometer problem title record
No rebuilt/rebuildable title record
No salvage title or salvage auction record
No water damaged title record
No NHTSA crash test record
No frame damage record
No recycling facility record
OdometerCheck
Your vehicle checks out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 1993 Toyota Land Cruiser (JT3DJ81WXP0034347) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.
0 Problem(s) Reported: Mileage Date Reported
28 06/28/1993
29,000 02/23/1996 not included in rollback calculation
28,241 03/04/1996
43,000 03/27/1997
64,112 12/08/1998
68,187 04/02/1999
89,150 12/01/2000
89,457 12/07/2000
99,882 03/20/2002
126,800 08/17/2009
Information Reported! AutoCheck shows additional information reported to AutoCheck about how this 1993 Toyota Land Cruiser (JT3DJ81WXP0034347)has been used and other events. This includes reported accidents and corrected or duplicate titles and storm area registrations.
1 Event(s) Reported: 6 Vehicle uses checked:
Fleet, rental and/or lease use record(s)
No taxi use record
No police use record
No government use record
No livery use record
No driver education record
5 Event(s) Reported: 9 Vehicle events checked:
Accident record(s) reported through accident data sources
Corrected title record(s)
Duplicate title record(s)
Emission/safety inspection record(s)
Loan/Lien record(s)
No fire damage incident record
No repossessed record
No theft record
No storm area registration/title record
Full History
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Vehicle: 1993 Toyota Land Cruiser (JT3DJ81WXP0034347)
Event Date Event Location Odometer Reading Data Source Event Detail
04/26/1993 ME Independent Source VEHICLE MANUFACTURED AND SHIPPED TO DEALER
06/28/1993 ME 28 Motor Vehicle Dept. TITLE (Leased Vehicle)
07/26/1995 ME Motor Vehicle Dept. TITLE
02/23/1996 FL 29,000 State Agency PASSED EMISSION INSPECTION
03/04/1996 FL 28,241 Motor Vehicle Dept. ODOMETER READING FROM DMV
03/06/1996 FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL (Leased Vehicle)
03/08/1996 FL Motor Vehicle Dept. TITLE (Title #:70762187) (Leased Vehicle)
03/08/1996 FORT LAUDERDALE, FL Motor Vehicle Dept. TITLE (Title #:0070762187) (Leased Vehicle)
05/15/1996 FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
03/27/1997 FL 43,000 State Agency PASSED EMISSION INSPECTION
04/01/1997 FORT LAUDERDALE, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
04/14/1998 FL State Agency PASSED EMISSION INSPECTION
04/15/1998 FORT LAUDERDALE, FL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL (Leased Vehicle)
12/08/1998 STILLWATER, ME 64,112 Motor Vehicle Dept. TITLE (Lien Reported)
12/17/1998 STILLWATER, ME Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
12/22/1998 STILLWATER, ME Motor Vehicle Dept. TITLE (Lien Reported)
04/02/1999 STILLWATER, ME 68,187 Motor Vehicle Dept. TITLE (Lien Reported)
12/30/1999 STILLWATER, ME Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
01/07/2000 STILLWATER, ME Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
12/01/2000 SUMMERFIELD, NC 89,150 Motor Vehicle Dept. TITLE (Title #:571881003360134)
12/07/2000 GREENSBORO, NC 89,457 Independent Emission Source PASSED EMISSION INSPECTION
03/20/2002 LONDON, KY 99,882 Motor Vehicle Dept. TITLE (Title #:020790630130)
CORRECTED TITLE
REGISTRATION EVENT/RENEWAL (Lien Reported)
04/17/2002 SUMMERFIELD, NC Motor Vehicle Dept. TITLE (Title #:775053021076909)
DUPLICATE TITLE (Lien Reported)
12/26/2002 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
12/04/2003 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
06/12/2004 LONDON, KY Accident Source ACCIDENT OR VEHICLE DAMAGE REPORTED: FRONT CENTER
06/12/2004 KY Accident Source RIGHT FRONT IMPACT WITH ANOTHER VEHICLE
12/28/2004 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
01/04/2006 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
12/27/2006 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
03/17/2008 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
12/15/2008 LONDON, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
08/17/2009 MAYSLICK, KY 126,800 Motor Vehicle Dept. TITLE (Title #:092290810007)
12/29/2009 MAYSLICK, KY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
Nice looking truck. You might want to add a price for a straight sale.
This is my only vehicle at this time so a straight sale would be hard to accomplish unless the right meeting could be set up to make all the trades/cash happen. I do have a lead on one in Idaho that I'm interested in if anyone can scheme up a way to make it happen, I all ears.
It has developed a slight power steering leak. I haven't been able to trace it down yet. I did also remove the ABS fuse so the ABS light is on. I just didn't like the braking in the winter with the ABS active.
Awwww....You're selling??? But we were having so much fun! Well, I can't blame you, I'm thinking about it too....I might give ya some competition there too, lol. But for those looking, I've seen this truck in person, and been there the 2 times it was at the off road park. Its in really good shape and has been very well taken care of. Very nice and capable rig.
Higgin thanks for the bump it was great times, but we did pretty much own the park. For as little as I use it off road it just doesn't make since to keep putting miles on it.
New pics as of today 4/10/11
Lee, I can't believe you're selling! I was planning to build my 94 identical to yours after our Badlands trip. Can you PM me your price if you sold outright?
Pm me if you want to part with that shifter.
