For Sale 1993-1997 Cluster LEDs (13 Viewers)
License plate white LED
Some LED install tips:
For the cluster, make sure to leave the dimmer plugged in while swapping in LEDs. The LED's only work one way. If they don't work, flip them 180 degrees.
The small wire leads may need to be slightly manipulated to make full contact with the inside of the bulb holder. You may need to angle them outward or slightly pull them away from the LED.
We've also been playing around with the climate control. The problem is, the climate, like many of the switches have green tinted plastic. So even if you put white behind it, there will still be a green tint to it.
White LEDs in climate.
Blue LED's in climate with white LED on the bottom for the slider lighting.
I will take a white set. Pm incoming.
Canadian Shipping
How much for shipping to Canada? Vancouver BC, specifically.
Shipping to Canada will run $10 for standard first class 2-3 week delivery. That will cover up to about 12-15 LEDs
Do you have a picture of green LEDs in the climate control, or other buttons? I don't mind keeping the green color, as long as it's brighter. The stock bulbs are so crappy and dim!
I also have bulbs for the Shift Indicator. Almost everyone I know has the "D" bulb out.
There are 10 bulbs total in the shift indicator assembly. It wouldn't be a bad idea to replace them all. $10 shipped for all 10 or I can include them with your LED order for $8.
Do you have a list of all the bulbs you have for the 1996? I am in for all!!!
Thanks
This should be the same for nearly all Toyota and Lexus 1990-??
2x front indicator side markers
2x license plate illumination
1x per door (4 total)
4x per cluster
Other bulbs I have:
Shift indicator bulbs (P, R, D, etc)
1990+ Land Cruiser glovebox OEM replacement bulb
Bulbs I will have in 2-3 weeks:
Green LEDs
Dome light/overhead light in bright white LED
Other:
Climate control green LED conversion. You would need to send in the climate unit, I don't have any plug in LEDs
4x per cluster
Other bulbs I have:
Green LEDs
Other:
Ok, i will take all the plug in bulbs but i want the domes too so i can wait...truck is on the lift getting axle rebuilds so no rush. I want white for all the bulbs including all 10 indicators in dash plus the 4
Thanks
Man, should have wait for this set:whoops: anyway, got my cluster set today. Thanks for the fast shipping.
dash bulbs are the same as AC control panel bulbs .?
No. There is no real solution for a plug in led. We do custom LED work on the climate control, that's really the only decent option, but you would have to send in the climate unit for the work on it.
If you do find an LED/twist in option you will probably have issues with light intensity and direction.
did you think in some sort of core price solution .. ?
I have one climate unit, I will be getting a second one shortly. Then we can do a core trade out no problem.
I will let you know when I'm ready to go on that.
I got my bulbs in 2 days. I will be changing these and getting some HIR headlight bulbs this weekend. Thanks again.
