Buy only Toyota OEM parts. Buy only the thickest head gasket (there are different thicknesses available). I'm pretty sure everything can be had from Toyota USA, but you can buy from Partsouq, Amayama, Megazip, or some of the cruiser parts suppliers around. This is the parts list I've sent someone before (below).
With regard to radiator, just get it re-cored as thick as possible. Replace or service the viscous fan clutch. Replace your t-stat with the newer 2LTE OEM 82C part.
Do some searching on intercoolers. Actually, do searching and reading on all your questions; this has all been discussed many many times before.
Here are the full vehicle manuals that you should download:
Help!
Here's the part list for the cylinder head job:
11101-54121
Head Sub-Assy, Cylinder
[04.1990 - 06.1992] 2LTE..LJ7#
04112-54103
Gasket Kit, Engine Valve Grind
[08.1991 - 05.1993] 2LTE..LJ7#
11115-54084-F0
Gasket, Cylinder Head
[04.1992 - 05.1993] 2LTE..LJ7# MARK F
Order 14 of these:
90910-02080
Bolt(For Cylinder Head Set)
[04.1990 - 05.1993] 2LTE..LJ7# NO.1
Order 4 of these:
90910-02081
[04.1990 - 05.1993] 2LTE..LJ7# NO.2
11802-54021
Bearing Set, Camshaft
CAMSHAFT
[04.1990 - 05.1993] 2LTE..LJ7# STD
