Help!
Waukesha, WI
Does anyone know the correct torque specs for a Flywheel to crank? LJ78 2Lt-e R-150F (Manual) Single mass flywheel
I'm sure it's in the forum somewhere, but I can't find it and the sun is going down here in WI!
Thank you Thank you
pretty sure it was 80lbs.
well, not your engine, but 64-72 lbs on the 2h and 3f.
Here are the manuals if you don't have them. Look at page EG77 of RM520E. Flywheel bolts: 90ft/lb in multiple passes.
- This is a Denso manual that explains in detail how the 2LTE electronic diesel works. It's an excellent read:
V 3 P5ZGR01.pdf
- These are the engine manuals for the L series engines. They do not cover the electronic injection system, but everything else is applicable to the 2LTE motor:
RM520E (Main for 2L, 3L & 5L engines)
Dropbox - 2L 3L 5L ENGINE RM520E.pdf
RM582E (Supplement for 2L, 2L-T, 3L and 5L engines)
https://www.dropbox.com/s/1joci2o0xtg6ujv/2L%2C2L-T%2C3L%2C5L ENGINE SUP. RM582E.pdf?dl=0
Here is the manual that covers the rest of the vehicle (RM183E):
_KZJ70_HZJ_PZJ_chassis_body.pdf
2LTE pump specs:
2LTE_Pump_Specs.pdf
Another version of RM183E that is more complete (includes sections missing in the other version), but is a little mixed up:
Electrical Schematics for the Japanese 70 series (including LJ78):
V 3 P5ZGR01.pdf
2LTE pump specs:
2LTE_Pump_Specs.pdf
Thank you!
I have some of that, but not all. You are a life saver!
V 3 P5ZGR01.pdf
2LTE pump specs:
2LTE_Pump_Specs.pdf
Thanks Nick
AHN, thanks for the pointers, not sure why the link I have saved for Megazip isn't working but I will revisit the link you shared. I will definitely check out the other two as well.
Take care, ~A~
