1991 DLX 3VZE M/T No Start Electrical Issues (7 Viewers)
Eastern Shore, VA
First post in a long time on MUD, used to spend most of my time in the 60 series forum :). Bought a 91 pickup from a friend last year that I've been trying to get back on the road and have been banging my head against the wall for way too long.
It ran well when I bought it after sitting for a couple years. New battery, new gas and some seafoam worked its charms. The front suspension was HORRENDOUS, but I drove it to take trash to the convenience center on backroads last spring. Only issue was a stutter after shifting into 4th and 5th which I attributed to needing a tuneup, filters, etc.
Pulled the passenger front suspension apart in June. Replacing UCA and LCA bushings, shock, ball joints, sway bushings. Took longer than I wanted because I found that whoever installed the ball joint spacer lift hacked the UCA's up terribly. Got new UCA and corrected it. Everything on that side is back together awaiting proper torqueing.
While it was on jacks, I had been starting it every week or two to run for 30mins. No issues starting until about July/August last year. Our summer got terribly hot and I don't have a garage so I didn't get back to working on it much until the fall. About mid-summer I went out to start it and it just wouldn't start. Cranked and cranked all day but no fire. That is where I still stand today.
Trying to make it brief:
Ignition on - No CEL
Jump pins in OBD1 plug- No CEL
Checked IGN and Distributor coils and all were in spec in late summer. I have a parts 95 4runner and tried the igniter and coil from there, no change.
Check, cleaned grounds/mounting bolts on IGN
Cleaned ground under throttle body on head (other end of IGN ground wire)
Cleaned ground where battery main attaches behind steering pump
Checked harness next to UCA bolts in case I smashed/broke anything during suspension work. One wire, small black-brown, had hard twist but didn't appear to be broken. Can't confirm what it is from manual
Pulled ECU, checked mounting points, checked cables for tightness. Checked power with IGN on, white-red wires, are good. Brown grounds are good. Tried to ground CEL from plug at ECU "If you have a manual trans then the seventh wire from the bottom right should be violet and comes from the check engine light" from another forum. There are two violet wires but aren't anywhere near the 7th position.
Checked B+ at diagnostic port and have power with IGN on (second check that ECU is getting power)
Checked Fp port on diagnostic port with IGN on and fuel pump has power
**this should mean that ECU is at least semi-functional, but it has power and no spark or tach signal**
Checked all fuses and relays, all good
Pulled cable from VAFM with no change. Have power to VAFM, when I spin the dial (top is off) fuel pump runs. Cranking with VAFM held open, can smell fuel
Ignition coil has +12v on both wires with IGN on. Igniter has power too (when coil is plugged in)
Still no tach pulse, no CEL, no spark.
If it was just the tach and spark, I would definitely be deep diving into the distributor/igniter wiring. The CEL issue is really bothering me. My Haynes manual diagram is little help. The only ignition wiring diagram is for 4cyl engines. Online resources, every pinout and color for the wiring is different and none match mine. I feel like I'm honing in, but not able to see anything to lock in on the problem. I just want it to run so badly! My guesses are #1 damaged wire somewhere due to my other work, #2 ignition system fault, or #3 failed/partially failed ECU. My 4runner is an auto so I don't think I can swap that ECU to test??
I hate the 3vze but love this truck and the frame and body are in great shape. I'm hoping to 2JZ swap it (or 2UZ??) but wanted to drive it with the v6 for a bit if possible.
Any help is appreciated!
Thanks
-Matt
Wire that was kinked in harness near starter, above UCA bolts
Couple of photos of the truck with all four tires on
the wire shown as VC/VCC G-B.
wire color may not be the same but location should be.
@gnob I'm not at home for a couple days but I'll be on this first thing thanks! This confirms the ECU is sending signal to these sensors and therefore working, correct?? Rules out/confirms ECU is bad?
do you have a 5v at the afm and/or tps?
Ok at VC and VCC I have about 0.1Vdc
At the ECU I have 12Vdc on the BATT pin (harness side) with ignition off (constant). I have 12Vdc on the B1 and B2 with the ignition switch on. E01 and E02 show good continuity to the mounting bolt for the ECU as well as to the neg terminal on the battery and ground on the top of the intake. 12Vdc good across the same BATT, B1, B2 pins and E01, E02. So the ECU should be getting fed correctly.
Ground the violet wire coming from the CEL bulb and CEL light comes on with ignition on. So CEL is not burned out.
Anything else I should check? Kinda feels like a bad ECU at this point??
unplug the others sensors. ECT and see if the 5v comes back. ive seen sensors bad cause same symptoms.
verify the vc/vcc has continuity to the ecu
TPS, AFM, EGR temp, water temp sensor, anything else?
speed sensor if its at the tcase
Unplugged all sensors. No changed. Pulled the center plug off the ECU which disconnects any I may have missed and checked voltage on VC pin… 0.1vdc.
Pulled the lid off the ECU….
Oh yeah. Cratered the board where it burned too so replacing the cap isn't an option lol.
There are some used M/T ECU's on eBay, is it worth getting one or is there a decent chance there's something else wrong that may smoke a second? My other option is to scrounge the $ together and get a GS300 or IS300 runner and 2JZ-GE swap it. That's the end goal unless I find a UZ deal I can't pass up.
i imagine you're fine. 3.0 ecu should be plentiful.
what is your part number?
*New* ECU from eBay arrived today. Popped the lid to look for smoke…all good. Put it in the truck and buttoned up all the connectors I’d undone troubleshooting.
CEL came on with key. Cranked and 🔥!
Idling now for 30mins to get everything moving again. Thanks!!
