Hello, i have a VM motor!
Mine is a 2.5 cc 5 cyl turbo not intercooled, original from factory, but there is a version 4 cyl intercooled mounted on the last version of portuguese BJ 73.
The spare parts of VM are the same of mercruiser turbo diesel and BMW marine motors of the '90's year.
My engine has 330k km whitout major issues, at around 300k i refreshed the head .
This is the only problem for the VM, knowin all the world, but if you treat it well(warm up and especially cool down) will last forever as a diamond!!!!
That is really not what I want to do. Who makes a adapter plate for the 4bt to bolt to the H55f transmission?
So no one knows anything about these VM motors?
There’s a lot of hate for the 4BT, but I’ve owned a 4BT powered Cruiser and if you like loud, rowdy motors then it’s a lot of fun and super simple. You can buy parts at any NAPA.
The downside of a 4BT is its paint shaker-ness. You’ve got some options for some big hydraulic motor mounts, mine wasn’t bad at all. It did chew up driveline parts though, the low end torque is unreal. It would be a blasty blast in a 70 series. I’ve owned two Toyota diesels, I currently have a 13BT powered rig. The 4BT is a different experience.
You can do a GM configuration and run any old Chevy conversion to the H55F. Mine had an advance adapters set up and was perfect.
how would you compare the 13bt to a 4bt? I know the 4bt is a rattler...
The 4BT and the 13B-T have some similarities, but the 4BT is everything in extreme.
As mentioned, it vibrates like crazy, so we can get that out of the way. It’s got a really long stroke and you feel it, and because of the configuration of the crank and how low it operates, it’s like a jackhammer on your drivetrain. It ate 5th gear on my H55F 5 times (it was modified with a Marlin Toy Box which created a weak link, but still... if it wasn’t for this I would still own the truck). It likes low RPM and if you’re smart you won’t let it rev past 3200, and for idea fuel economy you want RPMs below 2000z After you get passed that stuff, it’s a really fun motor. It is the least stallable motor I’ve ever driven, and in law range it’s sort of like steering a freight train. The torque peak is way down low, so it had near instant oomph. You can also get some pretty wild fuel economy. I could get 25mpg out of a 6000 lbs cruiser on 37s, and it would eat biodiesel, WVO and pretty much anything else I tossed in the tank (after I replaced the fuel lines). With a 3” exhaust it has a very satisfying snort to it, and a VE pump model is super easy to tune. Upgrades are easy to source, and you can buy parts for it from NAPA, generally you just order for a 12v Cummins powered Ram W350 and you’re good.
The 13BT is fun, I like it. Has enough oomph to get me around, does whatever I ask it to on the freeway, I get fuel economy in the law 20s. It’s a little rattly, It’s kinda stinky and smokey (but I haven’t started tweaking on it yet, so I don’t know how much I’ll be able to dial out), it’s a little grumpy when you wake it up in cooer weather, but it’s clearly designed for a passenger vehicle and is really easy to live with. Having had a 1HZ powered rig, all things said and done if I were you I’d drop in a 1HZ after you consider everything, but a 13BT and a 4BTA are still great choices for different reasons.
Good afternoon. Are you still working on the VM 2.5 TD 5-cylinder engine?Have a chance to buy a really clean non rusted BJ73. Its a 1990 BJ that has
a Salvador Caetano engine in it. That really is a VM 2.5 td engine. HR 588 is the model #.
So everything I have read about these VM diesel motors has been negative. You can't find
parts, manuals, heads are nickle plated, prone to over heat and the list goes on.
Does anybody have a input about these Italian VM diesel motors?
Anyone know where and if parts are still available?
Are these VM diesel's any good or is everything I read true?
Don't want to buy this BJ and then have to put a 4bt in her. The truck is just to cool and mint to
pass up.
Now when I went to see and test drive, it wouldn't start cause the glow plug relay was toast. She
was more than 2qts. low on oil. When I did finally get her started she really never stopped smoking.
Had to use a pinch of starting fluid to get her to finally start. I don't like doing that but I drove a
little ways and reallly wanted to test drive it.
The BJ73 drove really well. Had tons of turbo lag. Still wasn't the slowest thing but still not enough power to merge into traffic in the city.
Any input here would be great. Thanks
