SOLD 1989 FJ62 Orange County, CA
Status
Not open for further replies.
1989 FJ62. CA rust free. 240K motor runs like new. New cats smogged last year. Recent new radiator, water pump, alternator and battery. Includes rear tire carrier/jerry can swingout bumper, 40gal fuel tank, aftermarket lift by HFS, aftermarket wheels.
All OEM parts included to put back to stock.
Interior very nice, not perfect. Same with paint. It's been used, never abused or crawled. It's been taken care of.
THE BAD: Could use a valve adjustment. Driver's side steering knuckle weeps a bit. 3" long crack in orig windsheild, lower driver's side. TC filler bolt is stripped and weeps some fluid. Will need tires soon, though they probably have 10K miles left on em.
Nice looking rig. Cargo box and crossbars not included.
$16K
CLEAN TITLE
PM or email me at trfolger@me.com
Hi - looks like a nice rig but would need many detailed interior/underside shots as well as pictures of the issues you've mentioned above. Would be interested to check those out as I'm looking for a '62. Thanks!
Update, looks like both knuckles are wet, but the passenger side doesn’t drip. After storing for a year there was a little fliud on the driver’s side tire, but none under the passenger side. Looking at it now, they could probably both use to be done, but not necessary to drive it.
Driver’s side
Passenger’s side
Hi, While this sounds good these trucks do not like to sit for long periods. Tires sitting for short periods develope flat spots. battery will need trickle charging. Mice build nests in undesirable places, Wasps and ants get in and the exhaust system will rust out. And the list goes on and on. Been there done that. Mike
It was in the same building all last year. None of the things you mentioned occurred, and if you disconnect the battery it needs no charger. Started right up like I’d been running it all year. This is Southern California. Dry. Things don’t rust just sitting there, especially if indoors.
I should mention it is now titled in Massachusetts, but is a CA vehicle with all smog equipment intact and functioning.
Currently still located in Orange County, CA.
To clear up some potential confusion, it’s still in the same condition as above described. I have a valve adjustment scheduled for this Thursday, so the vehicle will be available for viewing after that.
The current asking price is $20K. This is a very good value considering it’s very good to excellent condition overall, and compared to other FJ6Xs I see being offered.
Thank you.
Status
