For Sale 1988 FJ62 (1 Viewer)
Year
1988
  1. 60 Series
Charlottesville, Virginia United States
Mileage
234000
Color
Blue
Hello all I have had this one for past few years. I would not hesitate to drive it anywhere. Super reliable and a super good driver. A LOT done over the last 15,000 miles
1988 Toyota FJ62 Land Cruiser - Link to PHOTOS 1988 Blue 62 - Blue Jay
Link to a few videos of the outside 1988 Blue 62 - Videos
234K on original 3FE Fuel Injected Engine that is super dependable and runs great.
Engine Oil change in the past 200 miles
Engine Compression Test from about a year ago all cylinders were 130-136 psig
In the past 15,000 miles –
Automatic Transmission professionally swapped to an H55F 5 Speed Manual, Toyota Clutch, Toyota Slave Cylinder Assembly. The transmission and all parts were brand new purchased from Toyota dealership in crate from Toyota Japan when swapped.
Transfer Case gaskets, seals and bearings replaced
Duracell AGM High Amp Battery
Engine Distributor replaced with OEM Denso unit in 2022
Front Axle Rebuilt – new bearings, seals, knuckle rebuild and new brake calipers, pads
Rear Axle - new bearings, brake cylinders and shoes
OME 2.5” Lift Springs and OME Shocks and steering stabilizer installed in 2018
33” x 10.5” BFG Mud KO3 Tires with less than 1,000 road miles rolling on Grey Powder Coated Toyota Steelies
Kaymar Rear Bumper with additional tail, brake and reverse lights in the bumper.
Trail Tailor Rock Sliders welded and bolted to frame in perfect shape
High Quality Custom Fabricated Winch mount with OEM type Front Bumper, KC Highlights and Ramsey 8,000 Lb Winch
Dynamat sound deadening throughout (Doors, Rear Quarters, Floor, and Kick Panels) Done to a very high level 2018
Tuffy Center Console
SOR Complete Carpet Kit 2022
3rd Row Seating added that are the rear seats from a FZJ80. They are removable see photos. I had planned to upholster them to match the factory seats but haven’t gotten to it.
Nice moderately high-end stereo with 400W amp professionally installed. Sounds good but will need a new head unit. I had disconnected the battery this past winter and the head unit is asking for a security code which the PO doesn’t know. If there’s a way to get a master reset code would be possible to get it going again possibly.
Original Toyota Tools
Things that may need some attention:
Windows work sometimes. They kind of have a mind of their own. I have manual window operators and matching door cards for manual windows to make the swap to hand crank windows. This conveys with the sale. Manual Window operators, Correct window cranks and correct matching Toyota factory door cards for the swap if there is interest in conversion to manual window operation
I bought $150 of seat fabric from SMS Fabrics that is an exact match for the seat fabric to reupholster the driver seat. Look at the pictures of seat. It is a bit better than typical wear on the driver but providing the fabric should the next owner decide to they want it to be perfect.
The AC blows cold but could be colder so would recommend a recharge before summer heat.
Oil pressure gauge sender or wiring issue as this past week it is reading high so this will need a little attention.
Previous owner installed a ARB locker in the rear but there is no compressor, solenoid or switch to operate it. So, if you want it to work you would need to purchase these items to make it functional. I have never really needed it since I just drive pavement and an occasional gravel road.
I have had (4) 60 and 62s through the years. This is a great rig and one of the best I have had, certainly not perfect but a really great driver. Would not hesitate to drive this one across the country.
Let me know if there is picture of something you want to see that are not in the above link and happy to get it for you. Or hit me with any questions.
Asking $27,500
1988 Toyota FJ62 Land Cruiser - Link to PHOTOS 1988 FJ-62 Blue J
Front Axle Rebuilt – new bearings, seals, knuckle rebuild and new brake calipers, pads, as well as rear brake cylinders and shoes in 2020
3rd Row Seating added that are the rear seats from a FZJ80. They are removal see photos. I had planned to upholster them to match the factory seats but haven’t gotten to it.
Windows work sometimes. They kind of have a mind of their own. I have manual window operators and matching door cards for manual windows to make the swap to hand crank windows. This conveys with the sale. Manual Window operators, Correct window cranks and correct match Toyota factory door cards available if there is interest in conversion to manual window operation
I bought $150 of seat fabric from SMS Fabrics that is an exact match for the seat fabric to reupholster the driver seat. Look at the pictures of seat a bit better than typical wear but providing the fabric should the next owner decide to they want it to be perfect.
Let me know if there is picture of something you want to see. Or hit me with any questions.
Asking $27,500
Very nice!
PO is a professional Series 1 Bronco builder and he told me he bought this rig for his wife to drive their family around in. They needed the third row so he added it. As it goes after a few months she wanted a mini-van so..............
It's a great driver and I just can't justify having two 62s. So, unfortunately this one needs to find a new home. Hit me with any questions or if you want to see more pictures I can send a link. PM me if you want.
Trying a another link to more photos
If this were closer and I weren't attempting to save for an airplane (lol), I'd have to give this some serious thought. What a clean specimen.
Is this still available?
Yes. The owner says that he is not on MUD often and the FB ad says to text him directly. His name is Dirk 434-284-3831
Went and looked at it last week. Nice rig with some sweet modifications. Bumpers look really good in person and the 3rd row install looks stock (aside from the leather seats) including the shoulder seat belts.
A few spots of bubbled paint but looks like a pretty good repaint.
Started right up and runs smooth.
Wouldn't sell for $60k on BaT but could be a daily for quite a while.
Thanks Cooper and nice meeting you. Best of luck in your quest. TampaCruiser ring me if you want to chat as Cooper mentioned I still have it. Thanks Dirk
Still for sale guys. Reluctantly will be heading to BaT if no one wants it here. Call me if you want to discuss and certainly would rather it go to Mud member in lieu of parting with it on BaT. I just can't keep two of these so it needs to find a new home. Call me if you want to discuss 434-284-3831 thanks Dirk
