SOLD 1988 3FE with all accessories near Detroit
Michigan/Costa Rica
  1. 60 Series
Good running 1988 3FE engine with all accessories. Shows 161,098 miles on the odometer. Includes everything from flex plate forward to fan: Alternator, power steering pump, all smog stuff, uncut engine wiring harness, air cleaner, etc. Air conditioning compressor is missing but mounting bracket is there. This is the perfect engine to upgrade your FJ60 to fuel injection. Uncut forward cab wiring harness with ECU also available. $650 OBO. I will not ship but can load. I’m scrapping out the truck as the body is completely rusted out, including the frame.
Update: I'm back in town and engine is still available. Some of you had inquired about compression: #1 - 168, #2 - 165, #3 - 162. #4 - 162, #5 - 165, #6 - 168. Obviously these readings were taken with the engine cold as it is out of the truck.
Very interested in this, but mainly need the head. Still available?
Yes it is still available, however, I am out of town until April of next year.
I'm back in town and the engine is still available.
I am interested.
Where exactly are you ? Trying to get freight quote.
Thanks
Right now it is just setting upright on a small pallet that would not be suitable for shipping. Let me take a look and see how best to prep it for shipping and get you an accurate weight.
And if you don't mind a close by address and if it is a business or residence. Do you have a way to load it / Fork lift ?
Thanks
Yes, I have a forklift available.
The weight for the engine with engine wiring harness, starter, alternator, power steering pump, air pump, fan and flex plate is 629 lbs. Add in the air cleaner with air flow sensor, ignition coil with igniter and air pump silencer and the weight comes to 649 lbs. These are actual weights. Figure 50 lbs or so for a pallet and you are around 700 lbs.
Edit: The height with pallet I estimate would be 36"
