Took the 62 up HWY 88 and made it 1/2 to Soda Springs, CA (~2500’) before we had to turn back due to lack of power and it began to sputter under load. I suspect a few things.
It’s like a carb that has mixture off bad vac leak. Runs fine at sea level, albeit the CD cable needs adjustment.
Thanks all,
MN
- Possible bad TPS still (connector needs replacing)
- MAF still not working correctly (doubting because its fine in other circumstances)
- Kick-down cable not set correctly
- Injectors need replacing
Thanks all,
MN
