Parting Out 1987 FJ60 in southern New Jersey
New Jersey, dump here please
CLOSING THIS THREAD OUT as of 10/19/16. I have lots of parts left that I'm posting in the parts section since the truck is just a pile of scrap now.
I'm parting the whole truck (no title). Frame is rusted beyond repair.
AVAILABLE (update as of 10/14/16):
Axles are out and ready for pickup - see separate thread in the parts section.
Will cut patch panels out of the body. Rear fender dogleg on driver's side is nice. Rockers are very nice (PENDING), drip rail around the top is near perfect. The top is now cut off (the whole top thru the pillars) and is available whole!
Wiring harness, fuse box, relays (PENDING)
A/C control panel with cables
Front heater core, box, ductwork
Rear heater
Emergency brake handle (no cable, it's bad)
Lower metal dash panel
A/C compressor (for onboard air)
Vacuum booster and brake master cylinder
Throttle pedal and most linkage
Keeping all four springs.
SOLD:
Front floorboards
Smog pump
Glove box door
Wheels (all five)
Rear bumper with receiver
HVAC bezel
2F, H42 trans, transfer case with crossmember, pedal bucket, clutch master & slave, lines, driveshafts, skidplate - everything necessary for auto to stick conversion.
Power steering box, pump, brackets, steering column with key and steering wheel, lower steering shaft.
All doors
Hatch and tailgate (buyer of tailgate is a buddy of mine, told me he isn't going to use it; LMK if you're interested ...
All glass (windshield cracked)
Cargo area panels (rear wheel well covers are still available)
No front bumper, fenders, grille, headlight buckets
Pickup preferred on parts too large for flat rate boxes, or meet up, or Mudship. The donor FJ60 is in southern New Jersey about a half hour outside Philadelphia, Pennsylvania.
The truck is about a half hour from me, also, so please text or call: 215 850 6331. Thanks!
Does the 2F have any smog stuff still on it? I'm specifically looking for the vac switching valves in the driver's side near the ABV system.
Cheers,
Stump
Cheers,
Stump
Hi Stump. The 2F is stock and complete. There is a lot of smog stuff on an '87 2F and even the FSM doesn't list the ABV in the abbreviations table. I happened to find it flipping through. Help me out here, send a pic of the specific part(s) or grab a shot from the FSM (check Spector's website) and circle the part(s).
In need of this rusted body part. Will you cut it, please?
fj62rearqtr-jpg.1211790
Thank you,
Monty
No problem, let me know how much of the panel you want. It would be nice if it would fit in a flat rate box, but it still has to be big enough to serve your needs ... Your call. Someone else asked about the rear 1/4 too. I think the corner is solid, but the bottom edge of that panel going forward to the wheelwell isn't, IIRC. Text me and I'll send you pics so you can judge for yourself. 215 850 6331
I'll be needing 13 inches in Height and 12 inches width. How much for this?
Thank you,
Monty
Thank you,
Monty
Monty, I gotta get down to where the truck is and see what's involved in cutting that panel out, which I will do as soon as I can. I'm mindful that price has to make sense for you also. Back in touch soon. Thanks for your patience.
What condition are the drivers side rear cargo area panels (three of them) in? Any tears or splits in the vinyl? Can you post or send any close-up photos?
Thanks.
Interested in the rear body opening weatherstrip that goes around the big opening, showed nag in the picture, shipped to 78133 also looking for lift gate interior plate that bolts to inside, about 9 inches long
Thanks.
I'll drag them out and shoot some pics.
I see the weatherstrip I believe you're referring to in the pics. I'll grab it for you. There is someone in line on the complete lift gate tho.
Would you have an alternator tensioner & all the bits that make it work? I don't need the upper bracket, just the tensioner.
I'm fine with pulling parts off the 2F but I need to get the motor running and sold first, in case a buyer wants those parts. Please watch the separate thread on the 2F. It's in the parts section. Thanks!
Not needing anything on the lift gate, the weatherstrip mounts to the body
I was referring to the weatherstrip attached to the body in the third pic of my first post. I'll grab that for you.
I have a list of parts to pull off the truck today for everyone who has contacted me. Please text (if you haven't already) if you're expecting pics. 215 850 6331. Thanks!
Please see the separate thread if you're interested in the 2F, H42 trans, the split transfer case, or the crossmember. I need the 2F to go first. :)
Thank you,
Monty
Monty, see the pics of that section of my truck below. I hadn't looked at it closely before ... your call. I'll be cutting panels (someone else has the rockers and the other quarter) on 06/19, so please let me know by then. Thanks.
