- Joined
- Mar 23, 2007
- Threads
- 22
- Messages
- 73
Hello
I'm hoping someone can help me out here.
Well, I'm a NEW proud owner of a 1987 4WD 4Cyl Toyota Pick-up.
When I got the truck it wasn't in the best shape.
So I decided to do some work on it.
I replaced the brakes and some rotten brake lines to the LSPV.
I also replaced the master brake cylinder.
I bled the cylinder and all 4 brakes.
After I finished bleeding the system I decided to test drive it
NO BRAKES!!!!!!
I stopped the truck with the clutch and parking brake.
I bled the system again.
No change.
I found out that the truck has a LSPV that also needed to be bled.
So I did and the truck only braked after the 3 rapid pumps of the pedal.
The 1st the truck doesn't stop.
The 2nd the truck has some resistance.
On the 3rd pump the brakes operate normally.
I have bled all the entire braking system multiple times with only a very slight difference each time.
What can I be missing?
I JUST BOUGHT A RUNNING '85 PTOYOTA PICK-UP FOR $150
NO BRAKES!!!!!!
No change.
