thanks man the images are a great help in getting an idea of where things are in the engine bay. i was thinking i was gonna have to crawl behind the engine to even get the injector pump out..
fortunetly i got the tools for the most part and the time while i finish up college and a garage i can use on request. i cant keep the car in there longer than a weekend though. i dont know how rusty it is. it has orgeon plates in the picture so it might be kinda rusty. crossing my fingers its not 2 bad. and i have no experiance with diesel injectors or diesels in general
so wish me luck
so wish me luck
Will need to see if some Toyota diesel folks can chime in. If you don't get any action here considering creating your own post asking for info on rebuilding a fuel pump. I believe several other toyota diesel motors use a similar style setup
- To be honest this is my first Toyota diesel so I can't talk specifics on rebuilding that.
** I'm pretty sure the injector pump is being turned from the timing belt, actually I'm positive it is....So, does that mean the timing belt needs to come off to remove and work on injector pump? Probably. So if that's true the repair has escalated to being a bit more complicated- How rusty is it?
- Shouldn't it still run even with a leaky pump?
I'll post a few below of what I already have but will take more later today when I get back from work. This car like many transverse motors can be a bit of a knuckle buster to work on. Personally I haven't had the confidence enough to do the timing belt but I also don't have a garage and work on a gravel driver... most other stuff around the motor is accessible, but it seems like you have always have to remove a bunch of stuff to get to what you need...So this all depends on your level of skill and time and space to work
You can see the injector pump in this photo to the right of the timing cover
