Thanks for posting some info Andy, helpful.
Yeah so I finally got my local Toyota guy to find time to let me bring it in the shop. She's going in for timing belt, water pump, and whatever other crap breaks as that's getting done.
The guy who bought it from you is right, the service procedure instructs to completely remove motor mount as part of the timing belt steps...Honestly for someone with a shop and skills, it might pay to just pull the motor out and work on it while on engine stand or bench.
So my situation is a little different than yours in the case that I've got no performance issues ( other than suspect cooling temps ) This engine starts up and idles better than any engine / diesel engine I've ever had. It barely even turns over and just fires right up. I'd hate to mess with that.
The timing belt sticker under the hood says 1992 lol. So if you believe that I am certainly due. However if you believe the previous owner, he claims the engine was fully rebuilt down to the heads back in like 2014ish..
I believe I could probably just do nothing and it would be OK but I'm too paranoid so I'll feel better once I know it's been done.
On a lighter note, I heard my fan turn on today while idling in traffic. The temp gauge showed right around 210F and then I heard it kick on. Sorta make sense, since I'm pulling temps from top of radiator and the sensor for the fan is at the bottom and seemingly a bit cooler? IDK
Once I heard the fan kick on, sitting at idle, I watch the temps drop back down under 200F which was pretty exciting to see.
I still believe under heavy load with hot outside temps, this engine would still get pretty damn... Curious to see if new water pump helps but I doubt it.
