Gretsch
Hello all. Recently picked up my first LandCruiser FJ60. 1984. Great condition overall. I am about 4 days into this so totally new to these vehicles. PO had the carb rebuilt to chase an engine idle problem. Seemed to fix the issue for awhile but during trip home with it on the highway, the engine started trying to quit. Loss of power and bucking as if to stop and then it came to life again. It did this several times. PO had told me that he had had issues with the fuel gauge reading correctly and suggested that I fill up halfway home to be sure I have enough fuel to get home. I thought maybe I was out of gas so I pulled in to fill up. He had it fixed but had not had time to test it before selling it to me so said to just get gas to be safe. Only took 7 gallons so I think gauge is reading fine.
Tonight at dinner the cruiser just quit. I was able to restart it but would not idle correctly. Kept stalling. I thought again maybe I was out of gas so I limped into a gas station and filled up. Still had trouble starting it and keeping it running. Finally after multiple tries it sprang to life and I was able to get it to stay running.
My first thought is fuel starvation. I have ordered a new OEM fuel filter to see if the old one is getting gummed up and clogged. I do not show any evidence it was replaced with the carb rebuild, but I am not sure. It looks pretty new but I am replacing as its a new truck to me and now I will know its done.
What else should I look at with this problem? The tech that rebuilt the carb says the "Float was not set right and main jet plugged up" in his diag notes. So he rebuilt it. Could this be just from a bad rebuild job? Also if the fuel lines are old, could they collapse under pressure and block fuel flow? I have also read that vacuum leaks can cause this sort of issue. This cruiser also had a new set of plug wires, new cap and rotor and was tuned just before sale. Maybe a problem there. Any help would be appreciated. Thanks in advance.
